0488 0460 0338 0611 0536 0472 0465 0209 0215 0433
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
SOURCE: need phillips magnavox code to put into dish network remote
I'd be happy to help you with your request. The codes you are looking for are:
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
If you are satisfied with my assistance please use our rating system to evaluate my service. Thanks for using Fix Ya!
SOURCE: URC 3220 REMOTE
just try to program the remote by hitting code search on the remote and then continuously hit the power button until the tv turns off and then cut it back on and the tv should be programmed, good luck! make sure that you press and hold the code search button until the light comes on and then the power button.
SOURCE: NEED TV CODES FOR PHILIPS
Here are the codes for your philips tv:
SOURCE: I need a code for
Hello
Setup codes for Philips TV with URC-3021 universal remote control are:
0054, 1454, 0690
OK.
