How to enter simulation mode
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: sharp copier AR5316 how to enter simulation mode
# interrupt C interrupt 26 start 6 start 4 start then turn off then on
SOURCE: how to enter in simulation
perform the following procedure to enter the simulation mode :-
press " # " key >> " Interrupt " key >> " c " key >> " Interrupt " key >> " 42 " >> " start" >> " 1" >> "start" ( this to reset the the drum indicator and replace 42 by 20 to reset the maintenance indicator).
I hope this help
SOURCE: how to enter in the
Try pressing #, *, C, *, to get into the simulation mode. To change user settings, try the menu feature. Good luck.
SOURCE: I need to enter simulation mode on Sharp MX-M260N.
Simulation Mode is # * C * What do you mean by the MIB? I know that you can setup settings for the SNMP on the webpage of the copier. Have you tried that?
