Cameras Logo
c
carol reid Posted on Sep 14, 2015
Set date on camara? - Cameras
How do i set my camara to date and time stamp photos?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
To see whether your camera can automatically stamp the date onto the photos, refer to your manual. If you require further assistance, please reply to this post and specify the make and model of your camera.
May 24, 2014 • Cameras
Sanyo put date on pictures
We have a Finepix F410. The trouble that we are having is printing off photographs that have the date imprinted. The date is on the camara display and is in the "on" mode. Any thoughts??
The Date and time is saved more or less as an add on to the picture file, not as part of the picture itself. So you're not going to get a date printed when you print the picture.
If you RMB click on the .jpg file when its on your PC, and select properties, it will also show the date. Until you edit it that is.
The only real way around it is to A) Buy a camera which has the option, B) Edit the photo, adding the date prior to printing or C) Write the date on the back as we used to have to do.
Can I download pictures from my digital camera onto my Dell Latitude d410? If so, how?
You can download from any digital camara.Load the CD that came with the camara or obtain one if you can. You need the interface cable that is purchased seperately. You do not specify the camara spec so you will need to Google the" model and pc interface cable". If you have the cable then the next step is the camara driver which should be on your cd that came with the camara. Plug in the cable to the camara and to the USB port on the PC (make certain the camara is set to the Play position or PC). Windows will ask for the driver location. Insert the cd and continue. If windows does not see the driver you will need to locate it manualy from the cd or on line and download it to your desktop from the manufacturers web site. All camara companies have a support website for the drivers. Once the drivers are loaded then you need to switch the camara to the Play position so it can be seen by the computer. Go to the control panel in windows and select system then hardware then devices. If all went well you should see the camara listed as a device. Now you need the camara software or a picture viewer from the web. Here is the web kocation http://en.kioskea.net/telecharger/telecharger-653-picture-viewer
If all went properly 1. driver 2. picture software then you should be all set to handle your pictures. Good Luck Phil [email protected]
I purchased Cannon a480 camara . The user manual
You can go to the support section of the Canon website and download a manual for your camera to your computer.
I have casio ex-z500 camara i want to know how to print date & time in the image
Digital camara and memory card
Basically picture files in memory card have corrupt data that's why computer doesn't recognize it.
HP recommends following action...
Close the HP Image Zone or HP Photosmart Software, disconnect the camera from the computer, and reset the camera. (can see this at HP Support)
2nd option is to find some memory card data recovery software on internet and use it to correct data files in memory card.
Thank you.
Oct 03, 2008 • HP Cameras
DSC-W120 How do I get the date on my prints.
You need to configure the option of printer for stamp Date/Time.
OTher way is to manually stamp Date/time on individual image by using Software that came with Camera
3helpful
6answers
Time and date
There is a small 3volt battery soldered on the main board that needs to be replaced. It has a yellow band around it, unless you can replace it yourself it's not worthwhile. If you decide to replace it beware of the flash capacitor charge.
AL
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
