Garden Logo
Posted on Sep 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The engine dies when you try to rev it
RYOBI MODEL NUMBER PBC 3046YB 30cc
Brian Szovati
Level 2:
Sergeant:
  • Expert 344 Answers
  • Posted on Oct 03, 2015
Brian Szovati
Expert
Level 2:
Sergeant:
Answers
344
Questions
0
Helped
103285
Points
899
You have to adjust the H needle on the carburetor. Quarter turns, when adjusting the high, the H needle, you have to hold the trigger in, throttle high... if it bogs, turn the h a little at a time and depress the trigger slowly until u hear the sweet spot...very simple fix.
2 Related Answers
Anonymous
  • Posted on Nov 05, 2009
SOURCE: cant get my ryobi pbc-3046ye brushcutter to start,
probley got a pin hole in one of plastic tubes
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Jul 10, 2010
SOURCE: Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
Repair video on removing cylinder from a ryobi power head.
Ryobi Technical Support Questions - HelpOwl.com
https://www.helpowl.com/Ryobi/Technical-Support
Ryobi - How Do I Replace A Piston On My Ryobi Edger. Ry 34006? ... Ryobi - Just Bought The Ryobi 30cc 4-cycle Power Head
1helpful
Can you help
Sounds like the cable in the upper shaft is broken. Start it without the attachments installed and see if the cable is turning.
Sep 01, 2014 • Garden
What is the correct oill mixture for Ryobi 30cc pbc 3046ye
Normally it's 2.6 oz per 1 gallon of gas. Purchase the 2 cycle oil with the squeeze top measuring the oz and it gives instructions for the use.
Sep 26, 2012 • Garden
Steps to run Ryobi RY34420 30cc 4-Cycle Gas Lawn Grass Weed Trimmer
This is the Cars and trucks section. You need an Expert for small engines to view this. Relist in a better catagory.
1helpful
Hi, I have a Ryobi PBC 3046YB strimmer/brushcutter, which worked perfectly well in its first season, used about 10 times. When first used the following season, the machine would start easily, but when I...
This does not sound like an air leak, normally an air leak will cause fast uncontrollable idle, if it sounds muffled i would be looking at a blocked spark arrestor, or exhaust port, or muffler.Slacken the muffler right off and just try running it to see if it picks up normally.
We lost the operator's Manual to our Ryobi 30cc 4 stroke gas trimmer. Where can we get a copy of it?
The unit should have a model number on it. You should write this number down and keep it in a safe place. When you have the model number you can go to this website and look for it by typing in Ryobi and (Model #). This should get you in the right place. =) www.manualsonline.com
Mar 29, 2011 • Garden
Hi I have replaced the coil on my Ryobi PBC 3046YB Brush Cutter and need to get the clutch back together, is there a certain way it must go? I replaced it once and it vibrated a lot, I pulled it apart...
My personal suggestion would be to go for these repair catalogs. I know this website reliable-store.com that I used to buy them from, and they have online it was very good manual. Go ahead, I bet.
Mar 05, 2018 • Garden
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
