Question about Blodgett DFG-100 Gas Single Oven
Change gas valve but still not getting the oven to light
  • 1,300 Answers
Http://www.blodgett.com/wp-content/uploads/DFG-100-200-ES-man-english.pdf?t=1498613846
look at the trouble shooting section of this manual to start the process.
Posted on Jun 28, 2017
6ya staff
SOURCE:
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
My Amanda gas oven Model no. AGS781WW is not heating up in the oven, nor does the broiler come on. The electronic ignition glows, I don't smell any gas in the oven. The cooktop comes on fine.
even if the ignitor glows it may not be getting hot enough to light the gas. if it does not get hot enough the gas valve should not open. try changing the ignitor, usually 30 - 60 dollars.
Jun 21, 2010 | Ovens
Oven ignitor glows bright red, but oven will not light. No smell of gas.
our ignitor glowed but still was not working right. it has to get to a certain temp before the gas valve will open. try changing it out. fairly inexpensive.
Jun 19, 2010 | Magic Chef 9122 Gas Single Oven
Whirlpool Acu Bake oven, burners light, broiler lights up, but oven wont light up. Oven ignitor lights up (glows) but it appears gas is not coming on, thru oven burner. Could the ignitor be bad even if its...
You just need a new gas valve. This is a simple repair for you and you can save a lot of money by repairing it yourself.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your brand and model number and we will get the correct part out to you right away.
We look forward to getting you cooking again soon.
Nov 06, 2009 | Ovens
Burner not lighting but igniter is glowing red hot.
The flame sensor is not activating the gas valve. Check or change sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 22, 2009 | Maytag CWG3100A Gas Single Oven
Gas oven not reginiting automatically
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jul 18, 2009 | Ovens
GE MODEL JGBP oven lighting is intermittant.
Hi, If this is a gas oven, you will need to change the ignitor. This is a very common issue with gas ovens. The ignitor is getting weak and not opening the gas valve as fast as it should.
Please let me know if this helps you or if I can assist you further.
Vic
Jul 11, 2009 | Ovens
Oven will not light
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
Jan 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Model # fgf347awj propane oven will not pre-heat.
Sounds like gas valve is bad and the thermostat also. I would change the gas valve first. But when you said oven would not lite sure sign the gas valve is bad. New gas valve is about 50ish t-stat could be another 20. I would almost just get another gas stove at a used appliance store for 125 or something like that if unit is very old.
Nov 25, 2008 | Ovens
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Blodgett DFG-100 Gas Single Oven Logo
157 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Marvin
Marvin
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
