SOURCE: Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
SOURCE: safeguard mode error 06
Defective mechanism,
a stucked mechanism is
present. camcorders are
smart. it can detect error
and shut down itself for
safety. earlier models
domino the defect if
the user is not quick
enough to react when
something goes wrong with
the camera. You need
professional service to
fix it.
SOURCE: JVC Camcorder Model # GR-D270U
I thought this was a camera issue, but it ended up being a tape issue. So it shouldn't matter if you have the same model of the JVC mini camcorder as I did or not. Anyway, the tape has a tab that "locks" the tape to keep from recording over it accidently. I moved that tab and it started working. If your tape is stuck in the camera, you may have lost the tape already. Try to get it out of the camera without damaging the tape or the camera...more importantly the camera. You may have to take it to a professional to prevent damage. If you get it out undamaged, check to see if the tape is locked or not. Move the tab and try the tape in the camera again (unless you're afraid of it getting stuck again). In that case, try it in another camera. That's how I discovered that this was a tape issue rather than a camera issue...because I tried the same tape in a different camera and got the same error message. Don't despair if your tape comes out with part of it sticking out or crumpled, as long as it's not broken, you can salvage it. Even if it's broken, you can probably salvage the majority of the tape by taping it back together (call a professional, you may need special tape for this), just don't touch any of the undamaged tape or pull it out of the cassette too far and all you will lose is the damaged portion. I actually couldn't see the tab well enough to tell if it was in locked or unlocked mode since it's so tiny and my close-up vision is getting blurry, but I moved the tab to opposite of what it was and that seemed to do the trick. My mistake was in trying to save money with the cheaper tapes...next time I'll spend a little extra for the better tapes to avoid all this headache. Hope this helped. Have a great day!
