Cell Phones Logo
Stacey Gail Posted on Sep 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to charge it - Cell Phones
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Cell Phones Master 1,001 Answers
  • Posted on Jan 04, 2017
wwlvictoria
Cell Phones Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603862
Points
6027
Quick Charge 2.0 2port QC2.0+4port USB Charger 5V 9V 12V 60W USB Fast Charger for Mobile Phone Chornic Quick Charge 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
NoName Jack
Level 3:
  • Cell Phones Master 1,150 Answers
  • Posted on Sep 13, 2015
NoName Jack
Cell Phones Master
Level 3:
Answers
1150
Questions
Helped
232920
Points
4657
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
2answers
2answers
Had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
2answers
Iphone not charging
You may have to replace the charging port http://www.etradesupply.com/oem-apple-iphone-3gs-charging-port.html
2answers
My iphone 3gs those not charge what could be the problem
go to the iphone shop buy a new charge.maybe the charge don't match the battery.
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
4helpful
Not charging
Have try to use another similar charger to charge it to see if it will charge? If you have and yet it did not charge, it means the charger is not the problem.
The problem is the the charging port, the charging port of your phone is bad that is why it is not charging, all you need do is to change the charging port of your phone and you will see that your phone will charge.
Replace the charging port and you will see that the phone will charge.
Take care.
2helpful
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
3helpful
4answers
Phone won't charge
Hi, The Li-ion battery cahrging circuitary is some what complex. For most chargers, the charging procedure is divided into three main phases: ? Pre-charging phase ? Constant-current-charging phase ? Constant-voltage-charging phase In the Pre-charging phase, it utilizes low charging current to protect the battery. However,in most recharging situations, the charged batteries still have some voltage remaining, so the charger does not need to apply this action, and just passes it on to the next charging phase. The constant current and voltage charging phases are the main charging phase for recharging the batteries, where most of the charging energy is transformed into the battery. The maximum charging current for a battery depends on the battery?s rated capacity. For example, one battery rated 700 mAh usually can be charged at 350 mAh to 400mA, for faster charging effort. When the charged battery is Li-Ion, in the last charging procedure, the microcontroller normally maintains regular charging voltage while monitoring charging current to determine when the charging procedure should be completed. When the battery is fully charged, most of the electrical energy is converted to thermal energy, which can result in high battery temperature. In this case, the temperature monitoring function will be added for the solution. But since most Li-Ion batteries on the market also have an over-charging protection function, the temperature detect function is rarely used. So it is better to get your phone charging circuitary checked at a local store rather than to make a charger,coz both may cost you almost same. all the best my friend. regards sreejith
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
