Televison & Video Logo
j
jonathan birkenstamm Posted on Sep 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung TV Vertical Color Lines
46" LCD TV from Samsung, had it for about 5 years now. Started to get colored vertical lines on the TV. After about 5-10 mins of being turned on they go away. I have read this could be a bad T-CON board, but not 100% sure.
  • 2 more comments
  • Sp Gupta Sep 11, 2015
    Hi jonathan birkenstamm, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Can you please post the picture of the fault?
  • jonathan birkenstamm
    jonathan birkenstamm Sep 12, 2015
    I will try to get a picture. It doesn't always show up. When I do see the vertical multi-color lines they disappear after about 5-10 mins. I think they show up when the TV is cold and go away when they components start to heat up. But once I see it again I will take a picture of them. Thank you for the help.
    jonathan birkenstamm Sep 13, 2015
    I added a picture of the lines I see sometimes when I turn on my TV. These vertical colors went away under 5 mins of having the TV on and didn't return. This is what I have been seeing on an off/on basis for the past month.
    jonathan birkenstamm Sep 14, 2015
    Thank you everyone for the help and answer.
Electro Med Services
Level 3:
  • Samsung Master 6,694 Answers
  • Posted on Sep 13, 2015
Samsung Master
Level 3:
Answers
6694
Questions
Helped
1872021
Points
21433
The t con broad is faulty. Just replace it will solve the problem.
Samsung LCD TV Repair Identifying Samsung Con Board Part Numbers How to...
www.electro-medical.blogspot.com
5 Related Answers
Anonymous
  • 616 Answers
  • Posted on Aug 01, 2009
SOURCE: 46 inches LCD Samsung TV had vertical solid black
problem with the driver board, 50/50 chance you will also need the upper and lower buffer boards. Julio
Anonymous
  • 5 Answers
  • Posted on Oct 23, 2009
SOURCE: I have a sony Bravia 46
its called burn in and yes it can go away over time. Be sure to not leave a static image on the screen (like a paused video) and leave it for an extended period of time.
playing video with high brightness and fast moving action can further help the problem go away.
Anonymous
  • 139 Answers
  • Posted on Dec 29, 2009
SOURCE: vertical lines in my sylvania lcd tv
They go away after 10 minutes of what? **** She Wrote? Dancing with the Stars? Or simply being powered On? You have some cold solder joints on one of the PCB boards. Once they heat up they work perfectly. The only way to fix this is to have them reflowed by a tech with a soldering tool or have the board replaced. Good luck! Cheers
Anonymous
  • 608 Answers
  • Posted on Dec 10, 2010
SOURCE: Samsung 46" LCD LN46B650 started showing vertical
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Anonymous
  • 10594 Answers
  • Posted on Mar 28, 2011
SOURCE: I have a Samsung Ln32A450c1d
Basically it is problem of LCD Panel (screen) however some times T-Con board replacement fixed the issue (T-Con board is part of lcd panel but some part shop sell it separately). Main board is not related with this kind of problem.
Required T-Con board is available in ShopJimmy.com (click the link to view available boards)
If T-Con board replacement does not solve half screen vertical lines problem then LCD Panel will be replaced and it would cost approx new tv price.
Hope this info will help.
Thanks.
Why do i have a green line on my tv
Vertical green lines on tv screen - Samsung 60" LED TV ... - iFixit
https://www.ifixit.com > Answers > View > Vertical+gre...
Jul 5, 2018 · 6 answers
Unplug all cables except the power cable, turn it on and see if you still have the green line. If without any image input, the line is there ...
How remove colored vertical lines all over screen of my LED ...
Dec 9, 2015
I have horizontal lines on part of my TV screen. - Sony Television
Dec 18, 2017
SOLVED: Why there's a green line - Samsung Television - iFixit
Aug 6, 2016
F-Series Vertical Green Line - Samsung Television - iFixit
Mar 8, 2018
More results from www.ifixit.com
Why does my TV have green lines on the screen? - Quora
https://www.quora.com > Why-does-my-TV-have-gree...
Sept 17, 2016 - With the green always on, it suggests that the cable the connects to the panel may have a bad line. Whether or not the cable has moved a bit to cause a short ...
6 answers · 10 votes: If its the same on every channel it means your TV is broke. I'm not tying to be a wise guy ...
There is a very thin green line going down my TV screen ...
Jan 3, 2021
How can I repair a TV with vertical lines on the ...
Dec 21, 2016
What causes a horizontal line on a flat screen TV? - Quora
Jul 25, 2018
What does it mean if a Samsung TV starts displaying ...
Jan 29, 2016
More results from www.quora.com
How to Get Rid of a Thin Green Line on an LCD - ItStillWorks
https://itstillworks.com > rid-thin-green-line-lcd-36231
A line of solid color indicates stuck pixels within your LCD. ... Your LCD produces specific colors and images by altering the colors of the thousands of tiny ...
5 tips to get rid of stripes on your TV screen - Coolblue
https://www.coolblue.be > advice > tips-for-removing-li...
Dec 18, 2021 - You can read 5 tips on removing horizontal or vertical lines on your TV screen here.
Vertical green line on Samsung LED TV : r/hometheater - Reddit
https://www.reddit.com > hometheater > comments > ve...
Apr 18, 2016 - It is most likely dead pixels within the monitor itself. You can try a stuck pixel video on YouTube that will flash colors or even give you a ...
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
My ten year old sony plasma tv has vertical herring bone lines no picture just color lines. Is my picture tube gone.
If its 10 years old boards and or parts will likely not be available--average life on Plasma and LCD sets is 3-5 years.
I would retire it--recycle it and buy a new set.
46 inches LCD Samsung TV had vertical solid black lines and thin color lines. It cannot be watched
5helpful
Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
VERTICAL LINES AND THE COLOR CHANGES
are the colored lines all the way across the screen? with no video even menu does not show up i would say you have a bad panel take it back to the store
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
