Televison & Video Logo
Leland McCluskey Posted on Sep 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace fuse? - Sharp Televison & Video
Claude Kayser
Level 3:
Top Expert:
  • Sharp Master 9,098 Answers
  • Posted on Sep 11, 2015
Claude Kayser
Sharp Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061757
Points
28436
Sharp LC46D43U - Aquos - 720p LCD HDTV Service Manual
www.manualslib.com > ... > Service manual
Flat Panel TV Sharp AQUOS LC-46D82U Operation Manual. Sharp flat ... Flat Panel TV Sharp LC46SB54U - LC - 46" LCD TV Operation Manual. Operation ...
2helpful
Subaru liberty 2012 boot won't look, could it be a fuse and how can I replace it please
If the boot of your 2012 Subaru Liberty is not locking, it could be due to a blown fuse. Here are the steps to check and replace the fuse:
  1. Locate the fuse box in your vehicle. The fuse box is usually located on the driver's side of the vehicle, under the dashboard.
  2. Open the fuse box and locate the fuse for the boot lock. The location and labeling of the fuse may vary depending on your vehicle model and year. Refer to your vehicle owner's manual for the specific fuse location and labeling.
  3. Check the fuse to see if it is blown. A blown fuse will have a broken wire inside or the fuse element will appear melted. If the fuse is intact, it may not be the cause of the problem.
  4. If the fuse is blown, replace it with a new one of the same amperage rating. You can find replacement fuses at most auto parts stores.
  5. Test the boot lock to see if it is working properly. If it still doesn't lock, there may be a different issue that requires further diagnosis by a mechanic.
Note: Always replace fuses with the same amperage rating as the original fuse. Using a fuse with a different rating can cause damage to the electrical system or create a fire hazard.
How to fix fuse clip in the fuse box for the heater fan in 1989 Chevy truck no use to replace the fuse cause one side being burnt
To fix the fuse clip in the fuse box for the heater fan in a 1989 Chevy truck, you will need to replace the entire fuse box. The fuse clip is designed to hold the fuse securely in place, so if one side is burnt, it's unlikely that the clip can be repaired.
If the burnt fuse is the only issue, simply replace the fuse with a new one of the same amperage rating. But if the clip is also damaged, you'll need to replace the entire fuse box to ensure the new fuse is securely held in place and functioning properly.
2answers
Where is alternator fuse in 2004 Navigator?
You can find a selection of replacement fuses in the fuse box. Sometimes, they are located on the inside of the fuse box cover. Replace the alternator fuse by pushing the new one into place using your fingers.
https://itstillruns.com/replace-alternator-fuse-7608082.html
Blown fuse on fuel pump 1996 Ford explorer Replaced fuse drove vehicle home. Now it will not start.
A blown fuse is an indication of circuit overload. Did you replace the fuse with one of the same value or higher? is this the standard current rating for that circuit (usually marked on the fuse cover.
If the engine cranks remove a spark plug tape it to the intake manifold or somewhere where there is clean bare metal (please not near the battery) check for spark if ok reinstall plug if not replace the ECM fuse and relay with alternatives in the fuse box if this gets the pump going replace the ECM fuse and or relay then check for fuel turn on the ignition you should hear the pump run and then shutoff if not replace the pump fuse and relay with alternatives in the fuse box if this gets the pump going replace the pump fuse and or relay
Replacing 140 amp fuse in lexus gx 470
Replacing 140 amp fuse in lexus gx 470 - Fixya
www.fixya.com/.../t26021201-replacing_140_amp_fuse_in_lexus_gx_4...
24 mins ago - The battery in my lexus gx 470 needed to be replaced it was hooked up wrog and the 140 amp fuse was blown how do i replace the 140 amp ...
HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS ...
www.fixya.com/cars/t24496313-replace_140amp_fuse_lexus_gx470
May 24, 2014 - HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS GX470CAN"T GET THE FUSE BOX APART TO UNBOLT THE FUSE - Dodge 1997 ..
Black decker bna17 mini fridge
I am having the same problem. Replaced the fuse with fuse holder and 3A fuse but the new fuse blows immediately. What do the diodes look like? and how do you replace them?
Outside fusebox location on Pontiac Montana 2005 3.4L the one under hood
FUSE BOX
There are few related help links for vehicle fuse box.Go through the list and click the required link:-----
2009 Toyota Corolla: Fuse Box Module Removal?
http://howtobyme.blogspot.in/2012/05/2009-toyota-corolla-fuse-box-module.html
1986 Chevrolet Corvette Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/1986-chevrolet-corvette-fuse-box-diagram.html
1996 Chevy Cavalier Cluster Fuse Box Diagram?
http://schematicsdiagram.blogspot.in/2012/04/1996-chevy-cavalier-cluster-fuse-box.html
2004 Jeep Cherokee Fuse Box?
http://whatisbyme.blogspot.in/2012/05/2004-jeep-grand-cherokee-fuse-box.html
2007 Saturn Outlook Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2007-saturn-outlook-fuse-box.html
Lincoln Signature Series Engine Compartment Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/lincoln-signature-series-engine.html
2005 Chevy Impala: Fog light Relay and fuse box diagram?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-fog-light-relay-and.html
Freightliner fl112 fuse box diagram?
http://technoanswers.blogspot.com/2012/01/freightliner-fl112-fuse-box-diagram.html
Where is Fuse box located on 2002 Honda Accord?
http://howtobyme.blogspot.com/2011/12/where-is-fuse-box-located-on-2002-honda.html
Toyota Hilux Surf Fuse Box Diagram?
http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
2006 PT cruiser Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2006-pt-cruiser-fuse-box.html
Ford inside fuse box diagram showing fuel pump relay?
http://technoanswers.blogspot.in/2012/02/ford-inside-fuse-box-diagram-showing.html
Ford fuel pump fuse layout diagram?
http://technoanswers.blogspot.in/2012/02/ford-fuel-pump-fuse-layout-diagram.html
Saturn Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/saturn-fuse-box-diagram.html
"Mercedes Benz" Ml 500 "Fuse Box Diagram"
http://schematicsdiagram.blogspot.com/2012/11/mercedes-benz-ml-500-fuse-box-diagram.html
2003 Cadillac Deville DTS Underhood Fuse Box Diagram
http://schematicsdiagram.blogspot.com/2012/11/2003-cadillac-deville-dts-underhood.html
Kia Fuse box?
http://technoanswers.blogspot.in/2012/02/kia-fuse-box.html
Which Fuse controls A/C system on 2003 Ford Taurus?
http://howtobyme.blogspot.com/2011/12/which-fuse-controls-ac-system-on-2003.html
1997 Chevy Malibu Cigarette Lighter Fuse?
http://schematicsdiagram.blogspot.com/2011/12/1997-chevy-malibu-cigarette-lighter.html
Where is Instrument cluster Light Fuse located on 1996 Honda Accord?
http://schematicsdiagram.blogspot.com/2011/12/where-is-instrument-cluster-light-fuse.html
These details will help.
Thanks.
2answers
I bought my car used from someone and it didnt come with the owners manuel and the cover of the fuese box is missing so i need to know which fuses r wich!! plz help
REPLACEMENT
  1. Locate the fuse for the circuit in question. NOTE: When replacing the fuse, always use a replacement fuse of the same amperage value. NEVER use one with a higher amperage rating. On some vehicles, you may have to remove a cover for access to the main fuse block 88256p51.jpg
    The fuse panel cover has a label with the fuse designations on it 88256p52.jpg
  2. Check the fuse by pulling it from the fuse block and observing the element. If it is broken, install a replacement fuse the same amperage rating. If the fuse blows again, check the circuit for a short to ground or faulty device in the circuit protected by the fuse. Locate the fuse which needs to be checked . . . 88256p53.jpg
    Fig. 1: Fuse locations and component identification 88256g71.gif
    Fig. 2: After you pull the fuse from the block, check the element 88006p42.jpg
    Fig. 3: Visual examination will reveal a blown fuse, but it should not be replaced until repairs are made 88006g76.gif
  3. Continuity can also be checked with the fuse installed in the fuse block with the use of a test light connected across the 2 test points on the end of the fuse. If the test light lights, replace the fuse. Check the circuit for a short to ground or faulty device in the circuit protected by the fuse.
7helpful
2answers
2002 Mercedes C320 wagon / fuse for cigarette lighter
Just did this on my 2002 C320. The blue 15 amp fuse is located in the front fuse box under the hood. It is either #47 or 48. If you already opened the driver-side fuse box, see if the paper fuse map is still there. If it is, find the fuse to be sure. Replacement is very easy, but there is a fuse puller tool in the spare tire well where your kit of replacement fuses should be. if you are in luck and you have a replacement, use the puller tool and replace the fuse.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
