Home Logo
J
Jennette Posted on Sep 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Debonair 450 33cs450-01 I have removed it thinking it took batteries.
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Sep 10, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5063080
Points
28436
Carrier Thermostat 33CS450-01 User's Guide ...
homeappliance.manualsonline.com > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
How to clear"service filter"after i changed the filter on Debonair 220 Carrier thermostat
Press mode and program together and hold to enter configuration. Press mode until option 11. 11 is the run time before reminder, put this to 0.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
I have a Carrier Debonair 450 Thermostat. The back-light of the LCD screen does not work. Neither do the buttons for the thermostat glow red or blue respectively. What could be causing this problem?
The t-stat needs a common and a hot. I know that is simple but it doesn't hurt to ask. Do you have the 24 volts needed to operate the t-stat? If you have 18 volts that may affect the lights.
1helpful
Carrier HVAC thermostat not fully displaying digital read out. Control bottoms doesn't work have to depress really hard and eventually works
Does it have a battery backup in the unit? If so replace them. If its an older model used frequently oil from your hands gets behind the buttons which causes intermittent connections and can cause display error. Remove the unit, carefully open it up and clean all contact surfaces with q-tip and a bit of rubbing alcohol. May solve your problem. While your at it make sure all wire connections are tight. Mark all wire locations during disassembly to make sure they go back in the right place.
Carrier debonair 400 won't heat
Hello my name is Willie of GMP mechanical services out of Centreville Virginia. I need some more Information about your AC unit is electric or gas heat. Is there a fault or fail signal in the digital display anywhere?
Carrier blank thermostat
Hello, sometimes this happens when the condensate overflow switch trips duento a clogged condensate line. You need to find the outlet of the condensate pipe and use a wet/dry vac to clean it out. The pipe will be 3/4 inch PVC. Let me know what you find. If the drain is clear then the problem could be related to a burned out transformer or dead batteries if the thermostat uses batteries.
Carrier a/c thermostat was working fine, then display went blank!
if it has no batt I would ck transformer for 24to26 volts no voltage replece transformer be sure trans has 115 volts to it trans should be in furnace section
Blank thermostat
Check voltage at unit. Also check the 5 amp fuse in the unit. If this unit has a float switch in the drain line check that. Rus
Carrier thermidistat screen went blank
Check the battery in the thermostat it is dead!! Should be 2 AA batterys!
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
