Trustworthy Expert Solutions
View Our Top Experts
My kenmore elite washer also stops after about 5 minutes. It will not finish a load, laundry is now backing up and i need a solution asap. I have unplugged the machine, I made sure the water outlets were all tight and secure,but i cannot get a complete wash
I have the same issue with the F20 code on my Kenmore Elite HE5T model 47089. I have had this machine since 3/07. Does the 2 year warranty on sensor smart electronic board cover this problem if it is true the board needs replaced? Is it easy to replace yourself or does a professional need to do it?
I have the Kenmore Elite HE3t Steam front load washer and have a similar problem with it. The F20 code comes on, sometimes right away when starting a load, sometimes when it's 1/2 done and the odd time I can get a whole load done without it coming on at all. What's going on? F20 means no water detected or a change in pressure. It's sort of hit and miss, not consistant at all. When I hit the cancel button twice to stop the cycle, sometimes the machine won't turn off and I have to unplug it. Is this a problem with the computer board or something simpler and cheaper to repair?
There is NO Code 20 on that model only goes to 15 plz check and repost
Are you sure the error code is correct? I can't an "F20" error code for this particular model Kenmore Elite. I only found an "F02" error.
My washing machine is not working properly.
I get a F20 error code and washer stops.
The kenmore elite washing machine displays an F20 error code and stops washing.
When I start wash cycle, about 6 minutes an F20 error code appears and washing stops.
What does f20 mean
Kenmore Washer Model 44092. Washer stopped and flashing code E-20
