Vehicle Parts & Accessories Logo
Posted on Sep 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My inside drivers door will not open the door when in the car
Derrick Schultz
Level 3:
Top Expert:
  • Vehicle Part... Master 11,405 Answers
  • Posted on Jan 29, 2019
Derrick Schultz
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2326800
Points
23972
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Nov 11, 2008
SOURCE: DOOR WON'T OPEN FROM INSIDE OF NISSAN ALTIMA 2002 ON DRIVER'S SIDE
There is a cable that attaches to the inside door latch release handle. The plastic that retains this cable is most likely broken. I have seen this before. If the retainer is not holding the cable sheath correctly, the entire cable moves when the handle is pulled and does not release the door latch.
Remove the door panel and inspect this cable. You will see 2 cables (one is for the door lock). If the plastic is broken, you will need a new interior handle assembly.
Hope this is helpful!!
Nissan Scope Technician- 10+ years experience in Nissan dealership
Anonymous
  • 41 Answers
  • Posted on Mar 22, 2009
SOURCE: can't open door
inspect the door hindge pins and busings it sounds like they are getting worn out and maybe due for replacement. also look and see if the spring in the hindge is still their. if all is well have the door adjusted properly to repair your problem.
ourhowse
Dar
  • 2007 Answers
  • Posted on Apr 29, 2009
SOURCE: Car door will not open from the inside
He probably pulled a rod off inside your door when he was probing. Or it may have gotten bent. You will be able to see what happened if you take your panel off.
Apparently, this happens quite often, and a lot of police depts. won't help you any more for this reason.
Anonymous
  • 776 Answers
  • Posted on Jul 18, 2009
SOURCE: driver's side door latch wont open door from inside
Go to http://www.hmaservice.com/ and register (vehicle by VIN). Afterward, you'll have access to technical information (manuals, wiring diagrams, service bulletins, etc) about your vehicle.
Anonymous
  • 819 Answers
  • Posted on Jan 25, 2010
SOURCE: key fob only opens drivers door
hit the unlock button twice. most fobs are programmed so you hit it once, drivers unlocks, and again for all the rest.
Why doesnt my G37x sedan front doors open?
2009 Door Problems - MyG37
www.myg37.com/forums/g37-sedan/253409-2009-door-problems.html
Dec 6, 2013 - 2009 Door Problems G37 Sedan. ... My problem is that my front driver side door will not open up from the inside or outside. My FOB key ... door wouldn't shut....now it won't open
Mar 5, 2015
Help! my windows roll down when i open the door!
Apr 10, 2013
Rattle in drivers side front door
Dec 11, 2010
Window Reset
Jul 28, 2008
More results from www.myg37.com
Driver's side door won't open!? - G35Driver
g35driver.com/...sedan-v36.../371407-driver-s-side-door-won-t-open.ht...
Mar 24, 2011 - I went to get in my car today and my driver's side door won't open - from inside or out. There's. ... The manual locker inside doesn't work. Problem with driver side door locking (and unlocking)
May 3, 2011
Dome light issues
Jul 3, 2010
More results from g35driver.com
Drivers door would not open - Nissan Forum ' Nissan Forums
forums.nicoclub.com/drivers-door-would-not-open-t466851.html
Dec 11, 2009 - My wife went around to the drivers side and used her key to see if she
Door is loked on rear driver side want open
Won't open from outside? Won't open from inside? Equipped with power door locks? IF so, and won't open inside/outside, suspect stuck power door lock actuator. Sometimes working the lock/unlock button will make the door unlock. If not, the door will require disassembly from inside to determine what the failure may be. If the door needs disassembly while in the closed position, the paneling/clips may get damaged FYI
How do i fix my drivers door it wont open inside/outside?
Very difficult to do. They sell jimmy kits that can be used through the window trim to get the door to unlatch. A locksmith will probably be able to open it for you or try to get the inside door panel off and manually open door using linkage inside of door.
1994 toyodriver,s side door cannot open from outside and inside even with key
The mechanism or door rod has been disconnected inside the door. Replace as needed.
Drivers door wont open
If it were me , I'd remove the inside door panel and take it from there. It may be that you can pry open the lock mechanism with a screw driver or a similar tool, allowing you to open the door - which obviously you must do. Even that, though, will not solve the cause of your problem. You may wind up at the dealer.
Will not open from inside on driver door. wil not open inside or out on door behind driver. will not open from inside on rear door behind passaengerUnable to buy partsrom dealer...
this sounds like the bar that is attached to the drivers door latch has either just popped off or has broken from the lever, you will have to remove the door card to see which one it is, hope this helps
Trunk wont open. latch does not work from inside
Make sure the drivers door is open and push the button on the drivers door to open trunk. Keep the drivers door open while you open trunk. If you close the drivers door before opening it, it won't open. Well this is what happens to our car. Don't know if it's a fault or the design but this does work for us.
25helpful
2answers
BMW X5 2001 -DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
1helpful
2answers
1993 driver side door can not open
The power door lock solenoid on the driver door needs to be replaced.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
