Depends on how fast you're seeing. Cheap LED power supplies are what we call, "half wave". This means that they only work on half the AC cycle, and do blink 25 or 30 times per second (depending on where you are). If that's what you're seeing, it would be normal.
If they're blinking at some other rate, do you have them on a dimmer? Some dimmers don't get along well with LED power supplies, and blink at 1 to 10 per second.
It has an in-line manufacturer dimmer pre-installed that controls up to 5 pucks supposedly with 120 volt supply plug in ballast. But only the first puck works and blinks. The others do nothing including even lighting up at all.
Sounds like the connection to the rest of the pucks isn't correct, and/or the dimmer is bad. You may want to contact the manufacturer or the place you got it.
SOURCE: LED LIGHT BLINKS 7 TIMES FAST OVER & OVER
Call philips to talk you through the reset option or arrange a replacement it may have a higher warrenty
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
SOURCE: blinking power light on 19 inch tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
