Quits after warm up wont restart
sounds like you have a fuel pump problem, fuel pumps will usually get hot and then shut off allowing it to sit 30 mins lets the pump cool down allowing it to start pumping, the way you can test it is get a can of starting fluid the next time it quits raise your hood and spray some fluid down into the throttle body and if it starts and then dies it is most likely your fuel pump, hope this helps.
