How do I manually set channels on zyxel 3110 (Post Office supplied adsl access etc?
SOURCE: Zyxel Bridge Mode Help!
Here are the information to configure Zyxel as bridge
http://www.zyxel.com/web/support_knowledgebase_detail.php?KnowledgeBaseID=3104&pid=20040812093058
With Regards,
TPV
SOURCE: Zyxel 660HW DSL LED keeps flashing
Try to change the Local or LAN IP Address of your Zyxel to 192.168.5.1 and do not configure the Zyxel router for PPPoE Connection. It should be configured as Obtain IP Automatically or Automtic DHCP.
Testimonial: "Thanks for your repsonse."
SOURCE: how do I change the wireless channel on my ZyXel
First connect your router to computer with ethernet cable.
Then you can access it with below defaults link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
If you are not able to access with above link then go t ostart menu ->run type in run "cmd"
then type in command prompt "ipconfig /all"
There is gateway ip is ip of your router.
YOui can access router with that gateway ip.
Then you can see configuration page .
Click on wi fi or wireless then change channel type to 4, 6 ,or 11 .These 3 gives best result.
Then save settings and restart router for take effect.
Let me know if you need further assistance.Thanks.
