To connect to the web with built in 3G, you have to pay for whatever service the 3G adapter is for. It looks like SVP tablets use EVO/WCDMA which is used by Sprint or Verizon in the United States. You will have to contact them about adding a tablet to your wireless pan, or signing up for a new mobile data plan for set price per month.
You'll need a recent version of Samsung Kies, instead of PC Studio, as a software interface to tether your Samsung Star 3G Nano to ur pc.
1. install the Kies, preferably over Windows 7 ultimate. 2. have ur activated Rs. 98 GPRS/EDGE account readied. 3. Run Kies. Connect ur phone to ur PC. Let it get detected by Kies. 4. Finally use the Tethering icon to begin the process. Default options will be fine.
If IPOD is working fine other than the connection problems,then the fault lies with either your cable or your USB port...
if its not working perfectly then try this:
1.slide hold switch to on and off a couple of times and then let it rest to off position
2.press and hold menu and select buttons together till an apple logo appears on screen.
3.Connect to system and this time it should be detected in recovery mode.
4.Restore and it should work fine.
Get one of these to sole your problem. ipod change their charging circuit I found one at Walmart in the ipod accessories section. Its called the Passport home dock adapter. http://www.scosche.com/products/productID/1695
- this accessory supports charging for the iPhone 3G, iPod touch (Gen 2) and iPod nano (Gen4) with most iPod docking stations - Snaps into any iPod universal dock and accepts universal dock adapters
The EX-10 was never intended to be an accessory to the IDA-X300, but should work with FM modulation like any other radio, by making sure the FM frequency is set the same on both units. There are four preset channels in the EX-10 but you can change each one to any frequency.
As for the bluetooth mic connection, you must have that connected for the bluetooth to work. You are better off installing a KCE-400BTi handsfree kit to get better functionality, increased phone compatibility, increased audio quality and the ability to use all of the newer iPods (Gen 2 iTouch, Gen 4 Nano and iPhone 3G).
Check the headphones. They might be burnt up. Test it out with another set. If that doesn't work, you can change the settings of the ipod while connected to itunes. Go to options, settings, and change the volume max to higher.
