SOURCE: Have a scrolling/rolling video on screen of a
Fault with its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: Vizio e701i-a3 problem. When I turn it on the
Very good chance it could have bad diodes. You will have to take the back off your TV and check to see if any have bad soder or need to be replaced
SOURCE: Vizio tv model:E502AR
In fact; you have to replace the display panel too to make the TV a new one. Contact any service technician. It will be best.
contact vizio,they may fix it for free
SOURCE: e701i-a3e. Why no picture, no sound?
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Bad panel contact VIZIO they will replace the unt for you
