I have a Bulova Quartz wall clock that the Moro needs replacing. Every time I try to take the minute hand off something inside spins and the hands will not come off....HELP!
I cannot remove the hands on my wall clock, when I attempt to remove them, it sounds as though something is spinning on the inside of the clock. Is the screw stripped maybe?
without seeing the clock .....are you sure it isn't something as simple as the hands ( arms) detaching from the centre spindle which continues to turn but without the hands. Alternatively have the hands become stuck on something on the clock face or become intertwined themselves ? Very simplistic but all I have to offer...
Jesus I can't believe no one answered this guy with even an "I don't know." in 6 years.
If it's like my watch, it's for synchronizing the second hand. If you press the button on the minute mark from the NIST time web site, when your watch is ten seconds fast, the second hand will stop for ten seconds. This makes your watch match the time clock. The really cool thing is if your watch is SLOW, if you press the button on the minute mark when your watch is twenty seconds behind the NIST time web site, the second hand will SPEED UP until it matches the NIST time. Very cool and this is **totally from my memory** because I just got my watch back from Bulova but I forgot to ask about the button.
I have the exact same issue with the minute hand resting at the 1 minute mark and now I have condensation under the glass. The watch is only 2 months old so I think I will return it.
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock.
When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming.
Rate me, plz.
Hello, I am not sure if I understand your question. Are you asking how this particular quartz movement operates?
All
Quartz movements are pretty much the same operational wise. They can
vary greatly in materials used for construction and number of jewels.
At it's basic a quartz watch uses a piece of quartz crystal called a transistor oscillator
to vibrate a tuning fork. This vibration is a is brought down by micro
processors to a meaningful number then converted into mechanical energy
trough the movement and hands.
In the case of a chronograph it means more internal gears and jewels. Although this is a good movement it is the low side of middle of the road.
The
G10.211 is an analog display of hours and measured time. These include
hours, minutes and a small jumping second as 6 o'clock. Mechanical date
and counters for 1/10 second, 60 seconds and 30 minutes with "ADD" and
'SPLIT" functions. Operated by 2 push buttons. It has 6 jewels.
If you want to know something more specific please just ask. Hope this helps.
The first thing to try would be to test the battery. If the battery is good the problem may be the mechanical works need to be started in motion. If it has swinging parts try to get them swinging. If it has hands set the time on the clock. Hold the the clock in your hand with the face towards you and rotate it clockwise a few times to get the gears moving. Sometimes just letting it sit upright for a day or so will be enough to let the clock start working. I hope this is helpful to you.
For some reason you cannot find the manuals on the Bulova web site any longer. But don't worry....
I have the manual for the Bulova Marine Star 96C30 Watch. This is easily fixable.
Below, I have typed the instruction on how to fix this issue as well as reset the time and calendar and a few extra tips in case you forgot....
Here is what it says to do if the hands don't match up with the display time (usually happens after you change the battery).
First, you must locate the buttons on the watch.
The "A" button is at the 2 o'clock position (upper right).
The "B" button is at the 10 o'clock position (upper left)
The "C" button is at the 8 o'clock position (lower left)
The "M" (mode) button is at the 4 o'clock position (lower right), and is the only button you can pull out to set the times, calendar and programming.
To RESET the watch and do the ZERO POSITIONING after changing a battery or having a display error, do the following.
RESET
1. Pull the "M" button out to the setting position.
2. hold down the "A", "B", and "C" buttons simultaneously for 3 seconds, then release them. All digit segments will turn on and display completely.
ZERO POSITIONING
1. Press the "B" button and all the segments in the digital time will reset to zero, with "UTC" showing in the main digital window.
2. Zero the "UTC" minute and hour hand (located in 12 o'clock sub-dial) to the 24 o'clock maker (straight up). Button "A" will move the hands clockwise, and button "C" will move the hands counter clockwise.
3. Press button "B" - "HR" shows in the main digital window. Adjust the main (large) hour hand to the 12 o'clock (midnight) position using "A" and "C" buttons. At the same time, observe the synchronized 24 hour hand (small dial to the left of the main dial), to insure that it also moves to point to "24".
4. Press button "B". "MIN" shows in the display window. Adjust the large minute hand to also point to the 12 using the "A" and "C" buttons.
5. Push the "M" (mode) button back in to its normal position. The watch beeps and at the same time the hands jump slightly. ALL RESET and ZERO POSITIONING are now complete.
6. Reset the time, calendar and other modes.
To set the time.
Note that changing the time in any of the cities will automatically update the time for all the cities.
1. Press the "M" button to move the mode hand to (TME)
2. Press either the "A" or "C" button to move to the desired city.
3. Pull the "M" button out to the setting position.
4. Press the "A" button. SECONDS will blink. Set them with "C".
5. Press the "A" button again, and MINUTES will blink. Set them with the "C" button.
6. Press the "A" button again, and HOURS will blink. Set with the "C" button.
7. Press the "A" button again, and 12 or 24 hours tim format will appear.
8. Push in the "M" button to its normal position.
To set thecalender
1. push the "M" button to move the mode hand to (CAL)
2. Set the city using the "A" or "C" buttons.
3. Pull out the "M" button to the "setting" position. The numbers of the "month" starts to blink. this is an "american" date system with the month first, day second, and year third. Use "C" button to adjust the month.
4. Push the "A" button. The date (day) will flash. Adjust with the "C" button.
5. Push the "A" button. The YEAR flashes. Adjust with the "C" button.
6. Push the "M" button back in. The calender is simultaneously adjusted for all cities.
Couple of other "tips".
Switching the time on the digital display with the time shown on the hands:
1. Press the "M" button until the mode hand is in (TME) or (CAL) mode.
2. Pressing the "A" and "C" button together.
The time will switch the between the main hands (analog) and the digital display.
Temporary Hand Retraction
Pressing and holding the "B" button will move the hands out of the way of the display. Repressing the "B" button will put the hands back at the correct time.
hope this helps.
As it had a battery change since it was new? If it uses a Miyota movement, it needs resetting after a battery change to restore the 12 position for the hands. It involves shorting 2 points on the back of the movement (needs back off).
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again. One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait. By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely. Do not forget to rate, please.
