You shuld go to your provaider and change new sim card with your number then you can make new code . no other way for that the code its block into the network wen you change the sim you will have new sim serial then the network will accept your new baring code.
Read more: Call barring password reset / barring password locked state in NOKIA E5? - Nokia 6303 Call Barring Password. 6303 Call Barring Password & Code :: Ask Me Fast at http://www.askmefast.com/Call_barring_password_reset__barring_password_locked_state_in_NOKIA_E5-qna4345257.html#q4175136
I want to unblock my nokia asha password barring is blocked
SOURCE: How to unblock barring password for nokia 5310
Call Barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
Call barring is a mobile phone feature that allows the user to set certain prohibitions on incoming or outgoing calls. This is an effective means to prevent the phone being used to make expensive international or premium rate calls, particularly when the phone is to be used by people other than the subscriber.
Many companies that provide handsets for business use now employ call barring as a security measure, to control their use and restrict calls to pre-approved numbers. The user's personal code must be used to activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring code. Initially this will be 0000. You should create a personal barring code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
SOURCE: my N5220 call barring is blocked how can i unblock
pls contact ur service provider.
thank u.
SOURCE: Hi My mobile call barring password blocked.How can I unblock it
if you forget the pass,then you must format your phone by : 1. Backup your data in your phone first. 2. Make sure your battery is fully charged. 3. In off condition, keep holding " * "," 3 ", and "Green/Call" button and turn it on. remember to keep the three buttons pressed until the "Formatting" screen show up. the security code on your phone will be reseted to default "12345",along with factory default. that's mean, remove your call baring too. sorry, this is the only way i know. maybe other experts know the better way? just use this method as your last resort :) regards
