I bought the plasma TV back in 2004, it turns on just fine but it does fade to black once in a while for about 5 seconds then returns. The sound is still audible while this is happening.
SOURCE: TV Won't Turn On
I purchased the TV using AMX card 18 month ago. They have an extended 1 year warranty on top of manufactory's. I just have this set repaired: replaced SD board, total charge is $550. I already file a claim and hope to get reimbursed soon.
SOURCE: panasonic 50 inch plasma
You should call for warranty service. If the set is very new try to get it exchanged.
There are some very heavy duty power supplies and many high power matrix drivers used in Plasma sets.
The description sounds like the noises are very loud. It is normal with any of these TV sets, if you put your ear right up to the back of the set at the vent holes you will hear some noises. These would be some acoustic harmonics from the power supplies and related circuits.
I am wondering if it is possible that there is something that is becoming less stable. If the set is working very well without any failure, so-far this is a very good sign. Before it gets to be a problem, I would have this checked.
On many models of these sets, they use fans for cooling specific areas. A bad fan can cause noise.
Jerry G.
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
