Due to virus on hard drive, had it cleaned. now unable to get fulpot poker site to accept log in password, unable to change password.
Try this link..
http://www.fulpotpoker.com/en/contactus/
SOURCE: unable to log on to
You can rest by clearing cmos. Open the case and remove the cmos battery[little round on the motherboard] after about 10 seconds replace & boot up.
SOURCE: computer will not accept password can not log on
Have you tried in safe mode? If so, then you will need a password reset tool to reset the SAM file in the registry.
There is one located here: http://www.petri.co.il/forgot_administrator_password.htm
But you will need to learn how to use it as these are tricky and can cause MAJOR damage to your OS.
When you boot up to the log in
screen type in administrator as user if you cant log in
During the boot up process you
will see on the screen for a short amount of time a certain key to enter set up
press and hold that key to enter set up BIOS scroll to set user password or
supervisor password you can change or remove the password from there if you are
still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable
"live" CD which contains software that allows you to change
paswords repair/restore/diagnostic
almost any computer problem also has a
bios reset tool which remove your password and BIOS password although you will
have to use a computer with an internet connection you will have to burn it to
a disk as an iso then change your firtst boot device to cd During the boot process you will see
on the screen to press a certain key to enter setup Press and hold that key
during the boot up process to enter BIOS the scroll down to advanced bios
features press enter change your first boot device to cd press escape then
press f10 to save to cmos to restart (note after you have removed the password
you must go back and change the first boot device to your hard drive)
Hope this helps
