Computers & Internet Logo
Carol Lentz Posted on Aug 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery charge does not last long - Computers & Internet
Rick Hurd
Level 3:
  • Master 285 Answers
  • Posted on Aug 30, 2015
Rick Hurd
Master
Level 3:
Answers
285
Questions
0
Helped
126056
Points
1051
If your laptop battery is more than 3 years old, it sounds like it needs replacing. Search online for your laptop model number to find a replacement battery for a low cost. IF cost isn't an issue, then write the model number down and go to an electronics/computer store for a replacement.
I HAVE SONY WALKMAN NWD-B103F- BATTERY DOES NOT LAST FOR 10 MINUTES-AFTER CHARGING ON COMPUTER
The battery does not hold charge. It is weak. Replace it with same type number. Brand name of the battery isn't a matter, check its type number printed on it.
After fully charged battery power lasted about 20 minutes.
Since it's brand new, return it. You didn't say what type of tablet it is, but they should last for many hours on a charge.
Battery charger reads battery full when dead
The battery is no longer good. You will need to buy a new battery. Don't over charge your batteries. They all vary. Expensive cordless tools will come with a charger that shuts off automatic to prevent over charging. I own cheap Skill drills that has served me well. These batteries lasted over 11years. It makes no sense. They should not have lasted more than 5 yrs., even 2yrs. I make sure I never over charged them, but they should not last that long. Freaky. Your battery is dead forever, sorry. I have others just like yours waiting to be recycled.
How long does the battery last when fully charged???
really depends on use and charging habits. If it is not lasting atleast half the amount than it use to last, then you need a new battery.
What i always tell my customers, is that when you first get a device with a rechargeable battery in it, charge it up and then let it die completely for the first time, then charge it up all the way again. This initial stretch of battery life will make a huge difference. Also try and get into the habit of charging it only when it needs to be charged. The less number of times the better
After charging d battery when we remove cabele
the battery sounds like it has bad battery memory and needs to be replaced. Before you replace it look for software to give you the battery's status (how much charge it holds out of how much it should hold by design. for exaple i am using ubuntu linux and my battery reads
Capacity: 29% (Poor)
Current charge: 14.3 Wh
Last full charge: 14.3 Wh
Design charge: 48.8 Wh
Charge rate: 10.0 W
now that is my bad battery for staying at home and leaving it plugged in all the time (that kills the battery) i have another battery that reads
Capacity: 97% (Good)
Current charge: 38.8 Wh
Last full charge: 47.5 Wh
Charge rate: 5.5 W
it is my battery for travel. the difference between the two is that the battery that reads Capacity: 29% (Poor) only lasts about 40 minutes but the battery that reads Capacity: 97% (Good) lasts 3 hours. you probably have a low Capacity.
3helpful
3answers
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Battery stopped charging
Yeah It Sounds like the battery is just had its last charge they only last for about 300 charges a piece i would get a new one go for at least a six cell they will last longer...Let me know if this works for you.
Battery charge
Dave you are correct. You should never over-charge anything like a Roomba, Cel Phone, etc. That will kill a bettery very quickly.
Loss of charge on 91 loyale station wagon
the regulator is in the alternator. it sounds like it isn't charging the battery anymore. battery voltage should be around 14 volts with engine running. also check connections at alternator to battery. have seen corrosion here keep the battery from charging
1helpful
HS850 charge doesn't last long
Sounds like you've got a defective model. Mine lasts about 4-5 days before I have to charge it.
Grand Canyon Tech
Grand Canyon Tech
