Because your time is off by 12 hours or PM instead of AM. Reset time correctly and date will change at right time.
Thanks so much :)
Thanks. :)
It's all good now! Thanks. :)
Probably because you have it set to 12 pm midnight and not 12 noon so at 12 noon it is actually midnight when the date will change
reset the time of the day to am or pm and any pm settings will change the date at 12 midnight.
Thank you so much!
My watch is working perfectly now, thanks so much. :)
My watch is now working perfectly, thanks for your time. :)
SOURCE: Hi, My watch is changing date at 12 noon instead
Your watch is 12 hours out of step. (The date changes every second revolution of the hour hand.)
Wind your watch forward 12 hours, (you may have to reset the date) and it will then change around midnight.
SOURCE: My watch keeps changing the
I haven't been able to find your watch on their web site but it sounds as though your watch is a mechanical (automatic?), if this is the case.....
The watch thinks it is midnight at midday, so wind the watch forward 12 hours.
Testimonial: "Thanks for the fix!!! It worked!!"
SOURCE: reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
Good luck and thanks for using fixya.
