Bose Lifestyle 12 System Logo
r
rick Posted on Aug 29, 2015
I need 1 audio input cable - Bose Lifestyle 12 System
1 Related Answer
Anonymous
  • 71 Answers
  • Posted on Mar 15, 2009
SOURCE: how to get video/audio input from Xbox 360 & digital cable input
Hook them all to the tv and with audio out from the tv run that to the bose 321.
Starting Beta SP UVW 1800 displays error 91-125. Apears like a feed back on audio channel 1. Nothinmg connected to it.???
Error 91-125 on a Beta SP UVW 1800 is a diagnostic code indicating a problem with the audio channel 1 input. The error message "appears like a feedback on audio channel 1" suggests that there is a signal present on audio channel 1 even though nothing is connected to it. This could be caused by a malfunctioning input or a problem with the internal signal routing.
Here are some steps you can try to troubleshoot this issue:
  1. Check all audio inputs and outputs to ensure that nothing is connected to audio channel 1.
  2. Disconnect all cables from the Beta SP UVW 1800 and power it off. Wait for a few minutes and then power it back on.
  3. Check the audio routing settings in the menu of the Beta SP UVW 1800 to ensure that audio channel 1 is not being routed to an unexpected location.
  4. Inspect the audio channel 1 input for any damage or corrosion.
  5. Try a different audio cable or input device to rule out any issues with the current cable or device.
  6. Check the manual of the Beta SP UVW 1800 for any specific troubleshooting steps.
If none of the above steps resolve the issue, it may be a hardware issue and you may need to contact the manufacturer for further assistance. It could be a malfunction in the audio channel 1 input circuit or a problem with the internal signal routing. A qualified technician should be able to diagnose and repair the problem.
1helpful
2answers
I have it setup on my Samsung TV with RCA cables, but no sound comes out
Why do you need to use RCA cables as a TV will produce sound through the internal speakers without any cables required.
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
1helpful
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
How do i connect my wii to my new samsung ue46d6530?
Input &
Output
HDMI 1.4 (3D Auto Setting/Return Channel):4
USB:3
Component In (Y/Pb/Pr):1
Composite In (AV):1(Common Use for Component Y)
Digital Audio Out (Optical):1
PC In (D-sub):1
CI Slot:1
SCART:1
RF In (Terrestrial / Cable input):1
RF In (Satellite input):1
Headphone:1
PC Audio In (Mini Jack):1
DVI Audio In (Mini Jack):1 (Common Use for PC Audio in)
Audio Out (Mini Jack):-
Ethernet (LAN):1
Initially I thought the problem was going to be no composite input on this television. However according to the specs there is one composite (yellow, white, red) input and that is where you connect the wii. Is the problem that you've already connected something to the one input and you're looking for another spot to connect the wii? There is a wii component cable http://www.amazon.com/Official-Wii-Component-Video-Cable-Nintendo/dp/B000JJRV90
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
1helpful
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
2 x component video input ( RCA phono x 3 )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
I have a rca dcr8052,and when hooked up with s-video cable i cann not get sound.
S-video only passes the VIDEO - you will need to make sure you also use the WHITE and RED connectors which are stereo L and R channels - for your audio input and for your audio output as well. Make sure you plugged your audio inputs in the right line input. Example, if you are plugging S-video in LINE 1, make sure your red and white cables are plugged in LINE 1 audio input !
2helpful
Which optical inputs should I use for (1) audio output from hi-def cable box (connected to HDTV with component cables) and (2) audio output from DVD (connected to 3805 with component cables?
Hi, the Optical and Coaxial inputs are assignable to whichever input you need them on. Plug the Optical cables from your DVD and HD cable box into any of the OPTICAL INPUTS (1 and 2 is fine, but write down your connections on paper)
You will then need to go into the setup of the AVR on the screen and assign the OPTICAL connections to the correct inputs (Probably TV/CAB and DVD.
Use the SYSTEM SETUP button on the factory remote, and you should see the on-screen menu appear on your TV. Go to INPUT ASSIGNMENT and choose the input for the DVD and assign OPTICAL 1 or 2...
Reply here if you need more help.
I need a diagram of how to hook up my jvc 5.1 surround sound to my tv, dvd and cable box
I my self don't have that exact unit, but most are similar, and i have looked up the specifications which are:
Inputs:
1 x S-video input
1 x Composite Video Inputs
1 x Digital Audio (TOSLINK) Input
1 x Stereo Audio Input
Outputs:
document.write(neg_specification_newline('1 x S-Video Output
1 x HDMI Output')1 x S-Video Output
1 x HDMI Output
INPUTS (coming from devices to the system):
1) The unit already comes with a DVD player, correct? If so you don't need to connect it. If you do, connect your DVD play via an s-video input, since a normal DVD player doesn't need a higher quality/resolution input.
2) Connect your cable box to the home theater system via a composite cable (the one with Red green blue), if it has composite outputs ofcourse. If not, do it visa versa with the DVD, if your dvd has composite. So make the dvd via composite and cable box via s-video.
3) Audio from the dvd, this would be via Digital Audio (TOSLINK) Input or stereo audio input. the digial audio will give you true 5.1 surround sound, and the stereo will only give you left and right channels, like you would hear from anything else (like a normal cd, radio, etc).
4) audio from cable box, would be again depending what you want. If you cable provider gives you alot of programming that has 5.1 surround sound (mostly HD channels), you would be better off with the digital audio. But if you watch more via your DVD, then connect the cable box via the stereo input. Again, this is to your preference, and which one you want true 5.1 surround sound from. The system should be able to 'emulate' 5.1 surround sound via the stereo cable too, but if your watching a movie, it can't really tell if a sound is supposed to come from the left rear or the left front.
Output:
5)connect to tv via HDMI if available, or S-video.
HDMI is much higher resolution (HD quality) S-video is normal cable programing or 'dvd quality'.
And the Tv would be left on mute or volume=0 since no audio is connected to the tv! All the audio should now come from your system.
Sorry if this was too vauge, but I don't have the same system and dont know exactly what/where all the connections are. If you have any other questions let me know.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
