Question about RCA 24V511T 24" TV
What does message catv 3 mono mean with a blank blue screen?
Power was out all day. Called cable co and they said all was properly hooked up. But the tv is running independent of the box. I can manually change channels but only the numbers change?
    Top Expert:
  • RCA Master
  • 53,757 Answers
If the power was out you may have to reset the box or turn the box back on so that the signal can reach the tv receiver
Posted on Aug 28, 2015
6ya staff
SOURCE:
I have a Jensen TS2750J model ... am trying to hook up and be able to process the HD that the home I rent a room from receives that signal from their cable company ... but don't know how to get my TV...
Hi.
The setting on your tv for the best signal is the HRC setting.
HRC stands for High Resolution Cable.
If you connect the cable to the blue jack, and set your tv to HRC, when you scan for stations, it should pick up all of them, not just the analog cable stations.
Now, some cable companies require an additional adapter, provided by them, in order to recieve the cable signal properly.
This adapter is called a digital transport adapter.
You should contact the cable provider, and see if the adapter is required in order to recieve their signal properly.
I hope this helps you out.
Good luck to you, and have a good day.
Jun 27, 2011 | Jensen Q2749J 27" TV
When i turn on ps3 all i get is a blank tv screen? hooked up thru hdmi. triied another hdmi cable i know works still a blank tv screen
when you turn your ps3 on ..try holding the power button down for about 10 seconds..that shud cure your delema..if the ps3 is working properly
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Only goes up to Channel 19.
Go into the TV's setup screen and make sure its tuning mode is set for "cable" (may say "CATV"). I'm not familiar with this set so I don't know exactly what the screen will say, but there should be some reference to channel setup, TV setup, tuning band, etc. It's probably set on "AIR" now.
Normally, when set for off-air reception, the set works properly for channels 2 through 13, and 14 up don't tune properly. Since you're getting channels up to 19, there may in fact be some kind of tuner problem. If the TV is already set for cable tuning, you may have found why the former owner was freecycling it. But check that tuning mode.
Apr 06, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Not working
Hello.
Blue screen usally means no signal.
This sounds like a cable/cord cennection problem.
If you are using a scart cable between the tv and the cable box
make sure the contacts are firmly inserted all the way,
Sometimes scart contacts are hard to get all the way in.
Howerver if you are receiving the CATV channels the sdame way as the rest of the channels, through an RF cord (antenna cable)
there could be a problem with your supplier of these channels
Best of Luck
Tech5508
Feb 13, 2009 | RCA 27V520T 27" TV
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
Channel
make sure that ur antenna/catv is properly connected to antenna/catv input of ur tv...better check the center lead if ur using coaxial cable..then try to reprogram/autoprogram ur set.
navigate also on tuner settings...via remote..
if u get nothin after autoprogram..probably bad tuner in ur set..u need a prof tech to fix it...thanks hope this help
Feb 05, 2008 | RCA TruFlat 27F520T 27" TV
This TV won't support 1080!
Low or poor signal from the cable company. Try another signal source such as a DVD play.
May 12, 2007 | Hyundai Q320 32 in. LCD Television
RCA 24V511T 24" TV Logo
173 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
