What else could be causing this problem. All connections seem to be solid. Thanks
SOURCE: I have a Panasonic TH-50PZ700U, with a green
It is the buffer X board. They are loacted at the botton of the set. Replace the one connected to the display panel directly in line with the lines in your picture.
SOURCE: We had a vertical line about 2 inches wide and
It is either the plasma panel itself or a connection problem, either way it will need to get serviced. Suggest you find receipt and phone Panasonic.
Cheers.
SOURCE: black line going vertical through portion of
Connections on c boards, c board bad or bad panel. Disconnect power supply from sus boards on sides before attemting to disaconnect connectors from c board to flex cables. arc from stored energy on power board will burn cables. reseat the connector closest to the bar . reconnect power supply. Next replace that c board by strip. next replace plasma panel.
SOURCE: MODEL: TH-50PZ85U I HAVE A VERTICAL
Hi
Thanks for using FixYa. As Plasma TV is a very hard working device so it produces lots of heat and around 75% issues in Plasmas are caused due to overheating. To start with you'll have to open the back of the unit and check for any bulged/bad capacitors on Y and Z-sus boards. As the sound is working fine so it seems that the power supply is fine, also check the control board for any bulged capacitors. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: Black vertical column
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
