Question about Sears Kenmore Elite Electric Dryer 69278
Will not shut off when cycles done. Shuts off only when door open
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 413 Answers
This sounds like someone has switched the wires on the door switch.
Posted on Aug 28, 2015
6ya staff
SOURCE:
GE Quiet Power 3 won't start when door is closed.
What is the exact model number? This may be an issue with the cables that connect the door to the power supply.
Apr 06, 2018 | GE Dishwashers
Hotpoint wma48 shuts down anywhere during cycle
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
May 23, 2016 | Hotpoint Washing Machines
Dishwasher starts in any type of cycle, runs for a minute, then shuts off as the lights blink out.
in general your wash motor can cause that. It gets old and you can hear the wash motor making a rumbling noise when it turns on. The increased load with cause a thermal coupler to turn the unit off.
Jun 23, 2014 | GE Dishwashers
2004 Pontiac Montana, when I open my drivers door the radio doesn't always shut off any more, I opened the passenger door & it shuts off, I think it's a door pin switch but I don't see a...
You don't find much with the door jamb switches any longer. Its all done inside the door with the switches being on the door latch.
the radio should still be able to be turned off manualy ;)
Aug 24, 2011 | 2004 Pontiac Montana
Will not spin or aggitate. giving a code of some sort
look under the door. there is a switch that will not allow the spin cycle to work if the door is open - like when you open the washer door on the spin cycle and the spin cycle shuts off until you close the door again, its a safety thing.
see if the switch works.
cost around $3.00 put in with a screw driver - good luck - aloha
Feb 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Sep 12, 2017 | Washing Machines
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
My dishwasher shuts itself off
The lights will typically blink when the door comes open. It may be that when the washer warms up, parts of it expands and allows the door to open slightly. It may also be that the trigger that registers the door being shut is not being tripped.
Aug 03, 2007 | Frigidaire 18 in. FDR252RB Built-in...
Sears Kenmore Elite Electric Dryer 69278 Logo
51 people viewed this question
Top Sears Dryers Experts
Andrew Taylor
Andrew Taylor
James Steuber
James Steuber
Level 1 Expert
Are you a Sears Dryer Expert? Answer questions, earn points and help others
