Car Audio & Video Logo
Q
Quinn Keller Posted on Aug 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset the pin # for the bluetooth on JVC KD-A815?
This unit is installed in my used car and I when I try to link it to my phone I get a message on my phone that the PIN # or Pass Key is incorrect. I have reset the device and used the 0000 code in the manual but I still get the same message.
Steve Sweetleaf
Level 3:
  • JVC Master 1,212 Answers
  • Posted on May 07, 2019
Steve Sweetleaf
JVC Master
Level 3:
Answers
1212
Questions
5
Helped
433382
Points
3475
3 Related Answers
Anonymous
  • Posted on Jul 19, 2009
SOURCE: Pioneer Bluetooth
The Code to activate it is 83423
Anonymous
  • Posted on Aug 08, 2011
SOURCE: alpine cde-126bt bluetooth connection
Hi, same problem (v3.80), but finally conected. I would say that is related with bluetooth name length of the phone.
Try setting the phon's name to something smaller.
Jordi.
Conected with an android device, Motorola MB200 (DEXT)
sparky1500
Matthew Spark
  • 1066 Answers
  • Posted on Jan 11, 2017
SOURCE: JVC KD-R316 install in Valiant Regal I'm replacing the stereo in my car, it had an aftermarket system. The new unit has power and will show display and eject disc but won't turn on. Where did I messup
did you connect the yellow wire from the stereo to an acc on circuit?
What is bluetooth adaptor for jvc kd s28
According to the installation manual for the KD-S28, the bluetooth adapter is KS-BTA100. You can find this on page 2 of the installation manual which is available from JVC's support page: http://books.jvc.com/ . Enter the model number and click the Model Search button. The direct link to the installation manual is http://books.jvc.com/Download/119824748/GET0754-002A.pdf .
I hope this helps. Amazon has a couple of the adapters for sale: https://www.amazon.com/JVC-KSBTA100-Add-On-Bluetooth-Adapter/dp/B004REMUJE . Other vendors do not report having this in stock.
How to connect my mobilephone via bluetooth to jvc kd-bt11?
You can try to have your cell phone look for JVC unit.
How to reset pin jvc kd-r810
This mosel does have Bluetooth it's not Bluetooth ready to and the model one of you gave Manual too is the is the rolling manual I have the kdr810 as well with same problem
1helpful
How to use jvc kd-hdr20 car stereo. I need to know how to fix balance,bass,bluetooth,ect.
To pair a bluetooth device with the radio, turn on the Bluetooth function of the device. Then press the SRC (source) button on the receiver. Select BT Audio or BT Phone, depending on the device you want to pair with the radio. Use the up/down arrows to select New Device and press the down arrow. Select Open and then press the down arrow. Then enter the PIN by using the left/right arrows to select a digit and turning the volume knob until the correct digit is entered. (For some devices, you need to enter a specific PIN. Consult that device's manual.) Press the down arrow to set the PIN. Enter the PIN in the device you are pairing to the receiver (if it doesn't have a required PIN). Wait for the message "Connected" to appear.
To use the device in the future, press SRC and choose the appropriate Bluetooth type. Then use the right/left arrows to select the registered device. Press the down arrow and then use the right/left arrows to select Connect and press the down arrow. (See the manual, link below, for setting the autoconnect or autoanswer.)
To adjust the sound system balance, press and hold Menu to open the menu and then turn the volume knob to Audio. Press the center of the Volume knob. Then navigate to balance and adjust the unit as needed.
The manual for the KD-HDR20 is available from JVC on the product support page: http://support.jvc.com/consumer/product.jsp?archive=true&pathId=54&modelId=MODL028465 . The direct link to the instruction manual is http://resources.jvc.com/Resources/00/01/14/LVT1960-001A.pdf .
I hope this helps.
I forgat my code for connecting mij mobile foon wiht my JVC KD-R801E car sterio, howe can i reset it.
First delete pairing of the device: Menu, Bluetooth, Device, Delete a device
Then add it again using another pin: Menu, Bluetooth, Device, Pairing
6helpful
How to conect my mobile in to jvc kd-bt11 via
The information is on page 10-14 of the Instruction book. If you don't have, download it from jvc website: http://books.jvc.com/booklist.asp?Model=kd-bt11j
Press Phone button
Use FWD/REV arrow to select the device
Press Down arrow
Use FWD/REV arrow to select new pairing
Press Down arrow
Enter PIN
2helpful
Bluetooth turn on
Hello imback2009,
The JVC KD-G140 does not have a Bluetooth option, either built-in or with an adapter. And as far as I can tell, it doesn't have a "mute" or "phone" wire which would allow installation of a generic bluetooth adapter, such as the Parrot. If you want to connect your cellphone, I'd recommend you look at an upgrade here.
Hope this helps.
2answers
JVC KD-AVX33 pairing problem
To inicialize to factory settings do: In "Setup" menu go to "others" menu, go to "Initialize" press "Enter".
With this you will loss all your customized settings
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
