I just bought it. It's used and I want to see if the machine works.
SOURCE: necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
SOURCE: necchi 3101fa thread cutter on the machine
It is at the needle screw area. Item #20 on the picture.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Sewing_Machine_Manual_Pics/Necchi_Pics/Necchi_3101i.jpg
Testimonial: "Awesome dude thx was lookin for like 30 min to find a damn diagram of the machine.... lol thx again. -THCjake"
SOURCE: Necchi 215A Sewing machine Could anyone help I
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Testimonial: "Thanks for the answer it did not work for me though"
SOURCE: I have a Necchi 3205
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
