SOURCE: Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
SOURCE: Goes to 60 degrees
check the back up heat coil or emergency heat available heat pumps have a defrost which need backup heat the three way valve outside will change position indoor coil will warm up to thaw ice
SOURCE: haier window airconditioner cooling is not effective
there is a temperature sensor bulb in front of the evaporator. check if it is too near to the coil. move iit away about an inch.
SOURCE: house is not cooling but it is blowing 60 degree
check to see if there is a 20 degree split between supply and return air. If its less than 20 than it might be low on charge.
SOURCE: room at 84. unit set at 65. outside is 94 degrees.
I brows the web to see the specs of your unit.In that case the unit cannot cool down the room temperature, you must consider the following:The volune of the room, it might be exceeded the specified capacity, the thermal isolation of the room, must be shield from leaks,and the materials used,the absorption of the matterial at first operation, the materials around the area will absorb coolness prior to room air, and the ambient temperature outside may affect the performance of the system,If too hot outside put a better thermal isolation inside.that helps? need thumbs up... sams_Ew0rks**
