Watches Logo
B
Becky Osborn Posted on Aug 25, 2015
Cannot get it to syn and keeps telling me "Device Not Found" and doesn't give option to pair
I am trying to pair my Apple series 4 cellular watch with my Mercedes c250 cdi year 2013.
unfortunately you can't pair an apple watch with any Bluetooth device other than your iPhone because it is an accessory and even though you can take calls and send texts with your watch it's not compatible with any device other than an iPhone but you can still take calls and texts with your watch {as long as you have a cellular apple watch}
Nov 03, 2018 • Apple Watch
The crystal face of the watch is cracked. We need to have the crystal replaced. Where do we send it in? Our watch repair doesn't handle things like that! It is an Akribos watch.
there are many different options, you can "google" watch repair, and choose someone to send it to. any local jewelry store should be able to give it to their watchmaker for a replacement crystal.
Jul 17, 2011 • Watches
1helpful
My garmin forerunner 50 won't pair with ANT agent
I'm not sure why it's happening, so, the only way to give you some advice is to follow this link:
http://www8.garmin.com/support/userManual.jsp It may help you to sort out your problem. Try all possible supports, manuals and FAQ's.
T6C failed after working OK for 1 day
Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
To re-pair the belt:
1. Remove the belt battery
2. Push the (new) battery into the compartment positive side down.
3. In your Suunto t6c, enter the settings menu and enter GENERAL.
4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
5. Scroll to HR BELT with [Lap +] and [Light -].
6. Activate pairing with [Mode].
7. Put the battery in with the positive side up and close the cover.
3answers
Can't pair garmin forerunner 50 with hrm and food pod
First you have to assume the battery that comes with your HRM would be new - keep in mind that it may be stored in the warehouse for many moons.
Given that, open and take out the battery - that should make a hard reset on the HRM itself. Restore the battery and try the manual pairing again.
The heart icon should pop up again.
Otherwise, you have to suspect the battery is low and need to be replaced.
Good luck
Pairing my garmin forerunner 50 with foot pod.
Tap foot to activate foot pod?
To pair Forerunner 305 with the Foot Pod:<code>Power on the device Press mode to access Main Menu Select Settings Select General Select Accessories Select Foot Pod Select Yes under Foot Pod Select Restart Scan Walk while device searches for the Foot Pod Wait for the alert Foot Pod On or Foot pod detected. Use indoors? If prompted for Use indoors? If you want GPS off, Select Yes If you want GPS on, Select No https://www.reddit.com/r/running/comments/1ehr5d/cant_get_garmin_foot_pod_to_work_am_i_missing_how
19helpful
3answers
Set time
I have just posted this problem on here myself but have also just found the solution after searching the internet so here it is..........
Hold down the top left hand button which is for the light and then a menu should come up saying 'LIGHT' & the option for on or off, ignore this & press the bottom left button, the next option is for the 'CHIME' & on or off, press bottom left button again & the option for 'TIME' comes up. Use the buttons on the right to alter the time until it is correct and then press the bottom left button again for the date and select the correct month and day and year and then you are all set up! Hurray, a watch that tells the time, im chuffed!
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
