Sewing Machines Logo
c
cathie stafford Posted on Aug 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When the embroidery unit is on the machine the "the feed dogs are raised lower them" comes on when I go to the embroidery edit or embroidery on my lcd screen and the feed dogs are down.
Jimmie Sill
Level 3:
  • Sewing Machines Master 706 Answers
  • Posted on Aug 25, 2015
Jimmie Sill
Level 3:
Answers
706
Questions
18
Helped
126800
Points
2291
The problem you've explained isn't totally clear. I'll try to give help on your problem.
On embroidery machines the feed dogs are suppose to be down while operating in the embroidery mode.
When you change programs to embroidery the sewing machine recognizes this mode and automatically makes the feed dogs go into the down position.
If you are attempting to operate embroidery and your feed dogs don't go under the plate then: Try the switch that is under the storage unit and switch it to free arm.
1helpful
Are feed dogs supposed to be up or down w/ embroidery brother LB6800
Well... the manual doesn't say to lower the feed dogs before installing embroidery unit, but carriage operation is likely no different then free motion which requires feed dogs lowered. So I'd say lower feed dogs.
I didn't find exact model but following is what the Brother site gave me for LB6800...
https://download.brother.com/welcome/doch000184/885v31_v32_v33_om04en.pdf
How do I Lower the pressure foot for sewing after changing from embroidery on my brother pc- 8500?
Would a manual help?
Brother PC 8500 User Manual
Are the feed dogs in the raised position? Is it a regular stitch presser foot or a darning foot? A darning foot is shorter in height so the fabric can be maneuvered without use of the feed dogs. Just some ideas. Could also be an embroidery setting that has not been deactivated.
2answers
The piece that moves the fabric is down ( as nedded for embroidery) it should be up for conventional sewing, please help me.
look in the operation manual for the feed dog lever and push it to the up position so the feed dogs will come up..
Dog feet seem as if they are not raising high enough to grab material and move it back. It their a simple adjustment?
It could be that your stitch length is not long enough to sew in a forward direction. Embroidery/Sewing machines have a feed dog switch to raise and lower for sewing or embroidery.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feed dog on singer m756 won't pop up
If this is a combo embroidery and sewing machine, the feed dogs have a switch to raise or lower them. If this is just a sewing machine, your feed dog linkage may be broken.
Singer futura xl-400 should the feed dogs be disengaged when embroidering
ABSOLUTELY! The XL models of embroidery machines are supposed to automatically lower when you put the embroidery unit on, but I have had an XL-400 and currently have an XL-550 and Quintet, and I have noticed on the latter two that the feed dogs have not always automatically lowered. Incidentally, to lower or raise the feed dogs, the lever (it's in the back) goes DOWN and OVER. If you are having problems getting it move, use a straight blade screwdriver and pop the little tip off--it's not necessary to operating the feed dogs.
Also incidentally, when you raise the feed dogs, you have to turn the hand wheel towards (ALWAYS towards you for anything) several times to get the feed dogs to actually pop up. You'll hear when it does that. They lower right away, though.
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
1helpful
After using the embroidery hoop you can not sew in regular mode, feed dogs does not come up and moved the cloth.
My Janome has a metal slide switch for lowering the feed dogs on the base of the machine in front.
Have you raised the feed downs again? Otherwise, turn off so that the current stich selected resets, and then turn on and select straight stich. Try again.
2helpful
5answers
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
How do I raise and lower the feed dog
If you look at the back of the machine you should see the button that will let you lower the feed dog. It looks like you slide the button one way to lower and then the other way to raise the feed dog.
To make it a bit easier just go to the following web site and move down to the pictures as there is one showing the back of the machine. The button would be on your right:
http://www.ebay.com/itm/JANOME-MEMORY-CRAFT-5700-SEWING-EMBROIDERY-MACHINE-QUILTING-TOO-ADDED-EXTRAS-/301088834718
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
