The KM-500MAE has 3 beeps in 3 seconds after 2 consecutive cycles. What should I check?
The KM-500MAE has 3 beeps in 3 seconds after 2 consecutive cycles. I checked the water then, it's OK. what is it mean? and what I should check?
Thanks!
Re: The KM-500MAE has 3 beeps in 3 seconds after 2...
Hoshizaki has service info on line in pdf format on servicing and trubleshooting. The machine itself has info on what three beeps message is. Sorry, no pinpoint fix
any beeping? beeping says what problem it is having.
Reset it while energyzed by pushing the button way back of the control board in the control panel section.
The switch needs to be set to run and valve to normal position, full ice bin sensor may be stuck to full position, exercise the sensor flap.
Post what you tried to remedy the situation for better help ideas. Trouble shooting instruction are included on the machine cover doors.
time the cycle. if it is only running about 5 minutes and going into harvest, look for sump loosing water. Look at where the unit drains (like a floor drain) while the unit is running to see how much, if any water is draining. does not take much to make an early harvest. also, sump may not be filling up completely but with just enough water to satisfy the float.
Staying in the freeze cycle too long. Usually about an hour. Several things can cause this. Look for water running even if machine is off. Possible stuck float switch. And more.
Rick at Restaurant Parts and More can get Hoshi parts. Just have model and serial numbers. He takes credit cards. Usually can it parts in about 3 days to your door.
I am assuming that it has run two consecutive cycles. I would first clean the machine inside and out. it should drop ice once cleaned, if not then open up the control box and find out which lights are flashing. I am almost certain that once it is cleaned it will drop ice.
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
The 3 beeps indicates that the freeze cycle is longer than 60 minutes. with the suction pressure at 20, it sounds like low on charge (freon). I believe this is an R 404-A unit. Other things to look for are: Stuck float switch (in the up position), Water valve leaking, hot gas valve leaking, txv not feeding properly, weak compressor. Look at high side pressure too. It should not go below 210 psi during the freeze cycle. Low pressure should be in the middle to upper 40's psi.
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
(Quated From Hoshizaki Technical Bulletin) An alarm code of 3 beeps every 3 seconds means that the control board has shut down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at the beginning of the freeze cycle. If the float switch fails to open and start the next harvest within 60 minutes, the board will automatically start the harvest cycle. If this occurs in two consecutive cycles, the control board will shut the unit down on the manual reset, freeze cycle back- up timer. The yellow fault LED marked “60 min.” will illuminate. This safety is designed to help prevent a freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are several things to check. Reset the alarm by depressing the white reset button to the right of the fault LED’s. This must be done with the power “ON”. Now check the float switch to see if it is stuck in the up position. A stuck float can occur if scale is present on the reed switch shaft inside the housing. To check it, drain the water reservoir, unplug the black float switch connector (K5) from the control board and check it with an ohm meter for a closed switch (zero ohms). If the float switch is sticking, clean it with ice machine cleaner or replace it as necessary. An inlet water valve which is slowly leaking by during the freeze cycle can cause a 60 minute alarm. If the inlet water valve is stuck wide open, it is unlikely that any ice will form on the evaporator. Check for a slow leak by allowing the unit to cycle into the freeze cycle and disconnecting the hose at the outlet of the water valve. If water leaks by during the freeze cycle, the water valve diaphragm is likely damaged or the small diaphragm bleed port is clogged with scale. Clean the bleed port or replace the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You should use normal refrigeration diagnosis procedures to check for one of these problems. If the thermostatic expansion valve is not feeding properly or the refrigerant charge is low, the evaporator will not form ice as it should and a long freeze cycle will occur. This could also be the result of the hot gas valve not closing completely during the freeze cycle or if the compressor valves are weak or inefficient. An inefficient compressor however, will usually show up first on the KM model through a longer than normal harvest cycle. This is because of cooler than normal discharge gas. Use proper refrigeration practices to repair a refrigeration system problem. While these are not the only reasons for a 60 minute freeze cycle, they are the most common and should be checked to resolve a 3 beep/yellow fault LED alarm.
