Ovens Logo
A
Anonymous Posted on Aug 24, 2015
Where can I buy an oven sensor for model FGF355CGBF  Frigidaire self cleaning oven.
Richard C Cohen
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Frigidaire Expert 318 Answers
  • Posted on Aug 25, 2015
Richard C Cohen
Frigidaire Expert
Level 2:
Legend:
Answers
318
Questions
0
Helped
120632
Points
917
The part you need is 316111202. Any good appliance parts store or website should be able to locate one for you. Your sensor should have about 1100 ohms at room temperature. Check the connector first before replacing sensor. They are notorious for causing problems. The only things that control temp is the sensor and the main board. If the sensor and wiring check good, then the main board is defective.
2 Related Answers
Anonymous
  • 188 Answers
  • Posted on Apr 03, 2009
SOURCE: Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Anonymous
  • 3361 Answers
  • Posted on Aug 10, 2011
SOURCE: F10 lights on at the
Open the bottom pan drawer, the number is on the leg.
Testimonial: "Thanks you! Now I can order it,"
I misplaced my manual and need to have instructions to use the self-cleaning feature.
First take out the broiler pan, insert and any aluminum foil. Remove any other tools or pans from the oven. Next clean any large deposits in the oven cavity with hot, soapy water and a cloth. Clean the oven frame, the area outside of the door gasket and the very front center of the oven bottom with soap and water. Once you are ready to start the Self-Clean cycle, press the Self-Clean touch pad. To change the length of the Self-Clean cycle, press the pad again, as needed. Press Start. If you want to have the Self-Clean delayed, press the Delay Start touch pad after the Door Loc message appears. Type in the start time with the keypad.
To stop this cycle, press Cancel. If the oven is hot, the door will remain locked.
Frigidaire has most of their manuals available on their support site: http://b2b.frigidaire.com/support/manuals.asp . The current link to the English version of the Owner's manual is http://manuals.frigidaire.com/PDFnotFoundCheck.asp?path=ftp://ftp.electrolux-na.com/ProdInfo_PDF/&folder=Lassomption&PDFtype=Owner&PDFfile=318205312en.pdf&model=FGEW3045KFB . See pages 24-25 for this information.
I hope this helps.
How do I clean my Frigidaire electric oven, Model FEF352AWF?
See page 13 for specific instructions.
ShopYourWay FRIGIDAIRE Free Standing Electric ShopYourWay
As tedious as it may seem I suggest that cleaning the unit by hand is the preferred process. Most failures that I have experienced have occurred just after the clean cycle is completed. There is a lot of stress during self clean and critical components are stressed and are more likely to fail. On two occasions I have had a failure days before family dinners. Usually in preparation for family we had been cleaning the oven. Both the temperature sensor and heating element have failed.
With a free standing oven repairs are a lot easier than with a built in wall oven requiring saw horses to remove and set. In any case plan to clean long before company in the event a repair results.
Why You Should Almost Never Use Your Oven Self Cleaning Function
2helpful
2answers
MODEL FGF355CGBF Door lock activates when check food in oven not allowing to continue to cook. occasionally stays locked
Hello Richard;
My name is Peter. I am a retired field service appliance technician.
You have an old unit. Some parts such as the door switch are no longer available.
You door lock should only engage when you are in the self cleaning mode. So you have a communications problem between the door lock and you control panel.
25601831-imv3tze4snahc4os1l3biiwf-2-0.jpg Latch Motor Substitution: 5304449471 Cost $180.00
25601831-imv3tze4snahc4os1l3biiwf-2-5.jpg Substitution: 316131600R Cost: $130.00
You may to replace one or both of these components.
Based on the cost of the parts and my service call experience you are looking at a $500.00 -$600.00 service call.
It's time for a new unit. Go into the internet and search; :Sears Outlet Store". This is a scratch and dent store where you can save several hundred dollars on a new unit with a one year warrantee.
Frigidaire Model FGF366BCA range Problem: Baking function & oven cleaning function stopped working, (broiler works fine).
I used the self clean feature on mine and found that it got so hot that it burned out the sensor and ended up with the same symptoms you are describing. Had to have the sensor replaced. DO NOT USE THE SELF CLEAN
Mar 11, 2011 • Ovens
Frigidaire Model CGLEF379GSA self-cleaning stove with ES340 Control: Won't self-clean after following instructions in manual.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
7helpful
2answers
Mar 29, 2009 • Ovens
Range Cleaning Cycle not Working
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
1helpful
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
