Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
Control Panel opens.
Device Manager opens.
If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
Pressing a notebook key once types several characters
The keys should be more responsive.
If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
Notebook beeps while typing
The Keyboard Properties page opens.
If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
Wrong characters appear when typing, changing keyboard language, or Dvorak
If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
The beeps no longer sound.
If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
The Text Services and Input Languages page opens.
If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
