Did the problem go away when you changed the toner or did it appear when you changed the toner?
I don't know if the toner on this particular model has a microchip in it or not. Most of them do. If you have another cartridge to put in it you can check if the problem follows the cartridge. If it does not then on the inside of the unit there is another microchip that interacts with the one on the toner cartridge and maybe it is bad or dirty.
Did you buy the toner as a compatible or refill?
This is an excellent video and explains the process and what to look for.
https://www.youtube.com/watch?v=nfBBiiVQs5U
SOURCE: USED TONER CASE IS NEARLY FULL
Hello sir; There have no waste tone bottle for this machine, but waste toner all stuck in the imaging transfer belt unit, on the right hand side door,pull it out dump the toner out and vaccumn it.
SOURCE: I want to empty my
you study this copier.If you are not have user guide you collect it by ricoh copier support webside.
Thanks
Tareq Bin Mostaq
Bangladesh.
