Question about Sentry FIRE-SAFE Combination Safe DS3431, DS3431
Model S0100. Safe is open but do not know the combination. Anyway to program a new combination?
Anonymous
SOURCE:
Anonymous
SOURCE: sentry safe V530
may have been 8 bucks , but it's 12 bucks now.
check out www.sentrysafe.com ,
look on right side menu for "keys" and/or "combination" .
Posted on Jul 09, 2008
Anonymous
SOURCE: Sentury Fire Proof Safe 1250
Is there any way to crack the safe by feel, ive seen it done before and have some experience in opening locks with pin tumblers, but not wheel tumblers. i can find the notch in the third wheel at around 10-15 but i dont know where to go from there. I would not be using this information for any illegal use, i just need to open my safe on my own, and soon, thank you.
Posted on Sep 21, 2008
Anonymous
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
Don Matthews
  • 309 Answers
SOURCE: I have a sentry safe 1610 that my combination will
Take the safe to a safe specialist in your area. They have a way to open the safe. Because safes are meant to be SAFE - codes are not divulged.
Posted on Nov 20, 2009
Anonymous
SOURCE: cannot open sentry safe, model 1230, have combo
cannot open sentry safe, model 1230, do not have combination
Posted on Mar 15, 2010
Have found a detroit electronic security safe in my home after living here for 7 years,was not told of this by previous owner.Is there a way for me to use this safe?
Yes. Any combination number...? If so then turn 1 at a time. be patient. You'll get it to open at some number.
Good luck
mai
Jun 16, 2017 | Miscellaneous
How to crack the code on my S0100 I forgot my combination
The only way to open the safe correctly is to contact the manufacturer. They can sometimes, with proper verification give you the general combo to get it unlocked.
Feb 15, 2015 | Cell Phones
Lost combination for model MSW 3617
I BOUGHT IT FROM A LADY AND SHE FORGOT THE COMBINATION TO OPEN IT... IT IS OPEN AND LOCKED OPEN...HOW CAN I PROGRAM A NEW COMBINATION FOR IT?
Apr 15, 2013 | Sentry Safe Fire-Safe Personal Safe
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
I can't open my safe. how can i know the combination of my safe. it is a normal safe.
Sorry, but you can't, That's why it's called a "safe".
If you lose the keys or the combination then the safe must be cut or drilled open. Some specialist locksmiths may be able to pick the lock or crack the combination, but it usually takes so long and costs so much that destructive entry proves to be cheaper. Many safes also have unpickable locks and uncrackable combinations anyway.
Jul 20, 2011 | Locks & Locksmithing
I have a sentry safe 1610 that my combination will not open it. Is there anyway to reset the combination or open the safe
Nov 20, 2009 | Sentry Fireproof Safe
Sentry s0100 forgot combination its still the default
You will have to contact sentrysafes.com dierectly.
Aug 06, 2009 | Sentry Fireproof Safe
Need defaul combination for sentri s0100 safe
You will have to contact sentrysafes.com directly.
Changing the combination
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You must have the factory combination in order to change the combination that was added to the safe and the factory combination can not be erased if that is the combination you are trying to erase.
All you have to do is press program & type in the factory code 2 times & that will erase the number you created.
Then to add a new combination all you have to do is: press program followed by 5 new numbers. Then to see if they new number works, just type in the new combination & the green light should come on & you have 4 seconds to turn the handle
Apr 24, 2008 | Sentry Fireproof Safe
Sentry FIRE-SAFE Combination Safe DS3431, DS3431 Logo
363 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Colin Stickland
Colin Stickland
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
