Sometimes when i rename a file and click the cursor button , the file name is not getting changed, it goes back to old file name .Please Note:i am not getting any error while renaming This has started happening after the Windows 10 upgrade
SOURCE: IBM Aptiva and verizon DSL
OK Win98 doesn't play well with USB, when Win98 came out USB was very new, and NOT supported properly untill Win98SE... and even then it is a pain and real problematical. I would suggest you get a Ethernet connected DSL modem.. Else ya gonna have no end of problems regardless of what ya do including "Flashing" I think that model PC has Ethernet built in? otherwise get a PCI Ethernet Card and use that instead of USB.. ya be good to go. I would also upgrade if possible to Win98SE PLUS install ALL Updates there are still Win98 suport on the net, simply Google for it.. good Luck.
SOURCE: Trying to rename a PLU
Hi. You should normally be able to program all 108 PLUs on the keyboard as long as they have been setup.
Turn key to Program mode.
SUBTOTAL
Type new name
00 (double zero button)
Press a PLU to set the name
SUBTOTAL
Mark
SOURCE: I can't change my desktop background picture, when
Please check user user rights whether it is limited or Administrator
SOURCE: how i have dell desktop optiplex 755, which
well you now need to go into my computer and click in the windows.old and you will see them there now you copy them across to your new setup and put them in the same folder you take them out of that should let you get everything the same as you had. the easiest way is to copy the folders DESKTOP, MY DOCUMENTS, and if internet is needed MY FAVOURITES but remember to put them back in the same place you got them from ok. hope this help and good luck
SOURCE: Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
