Where is a part that looks like a large paper clip located on a Dewalt DC 925
SOURCE: dewalt dc 988 cordless drill
posible motor problem, the built in magnetic ring in the motor may broken inside or just to much dust in it. advice when replacing motor also replace th switch for the cost $132.00 plus tax canadian. thanx
SOURCE: dewalt dc 980,when i spin the torque dial from 1
You need to get a new transmission. There is a spring and pin that get worn in the transmission. Dewalt doesn't sell just the spring and pin. You will have to get the whole transmission. The part number for the transmission is 397892-05 for the dc980. To change it you undo the screws holding the housing together. (Make sure battery is removed first.) Undo 4 screws holding front assy on and remove. Undo back cap screws and remove. Pull the right side cover off and leave drill seated on bench. Do not pull entire assy out of left handle. slightly angle the motor transmission assy and slide transmission off. Replace with new transmission. (Lining up teeth is not easy but keep at it until you get it.) Replace motor and transmission assy and reassemble in the reverse order above.
SOURCE: Hi i have a dewalt DC 988 combi drill, 4 years
It all depends on what is burning I'm afraid. When in use, run your hand around the back of the machine and handle area to see if anywhere in particular is getting hot. On the older versions of these (DW988) the leads leading from the switch to the brush holders would overheat and burn, also causing damage to the brush holders themselves. Is there any smoke coming from the rear vents, if so you wil probably find it is a motor problem and the smell would be the insulation burning off the armature. The only other thing to check would be to make sure the battery isn't shorting and getting hot, as this could also cause damage to the switch and vice versa.
SOURCE: How do i remove a dewalt chuck in the DC 988
go to the tip section and I left detailed instructions on how to do this, or try and go to my profile page under tups. Let me know if you still need more help
SOURCE: where do I get an owner's manual for a DeWalt DC
The manual can be found HERE.
There is a link (an adobe acrobat logo) on the top right of the page for the manual to let you download or email it to yourself under the Downloads heading.
