I've had 2 repairmen out. The first said I needed a new sprayer arm, so he ordered a new one. The next man came to put the new sprayer arm on. He said the old arm was fine, but he put the new one in. It still comes loose after every wash! I try and try to snap it down, but none of us have been able to get it on so it doesn't come loose during the wash cycle
SOURCE: Kenmore Ultra Wash Dishwasher
Thank you Catriver! You were in the zone! It's working like new! Many thanks!
SOURCE: Dishwasher is leaking on the floor during wash cycle
If this is a new dishwasher, then I suggest you call in a warranty issue on this one.
SOURCE: 18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
SOURCE: sprayer arm wont spin and soap sits in bottom
Hi-- Could be, but let's go over this stuff first. Remove the sump cover and spin the pump blade on the end of the motor. If it is difficult to turn or 'rough' feeling, then motor is probably bad. One time I found a bottle cap that a little Dennis the Menace had put in the dishwasher. It made a perfect plug for the sump intake! Anyway, if you can pull and re-install a dishwasher then replacing one of these pumps is easy. Part is about 140$. Let me know if this info helps. Please acknowledge this post. Thanks-Ed
SOURCE: soap dispenser doesn't open during wash cycle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
