Question about Pride Jazzy 1103 Ultra Standard Power Chair
Speed lights flashing - Pride Jazzy 1103 Ultra Standard Power Chair
Would a bad photo flash capacitor allow the camera to not take pictures at all?
Important Warning: Camera Flash Capacitor Shock! 'Do It ...
camerarepair.blogspot.com/2007/.../important-warning-camera-flash.htm...
Nov 22, 2007 - All digital cameras contain a flash capacitor. ..... I try try to take picsand it would only allow me to take one, and then say 'memory card full' (just ...
Canon PowerShot A75 Troubleshooting - iFixit
https://www.ifixit.com/.../Canon_PowerShot_A75_Troubleshooting
iFixitCheck power button; Drained/bad battery; Bad logic board ... The camera will not takea picture unless the flash is charged, which will be indicated by an orange ...
Shutter speed does not affect flash exposure
www.scantips.com/lights/flashbasics2.html
This D800 camera has a maximum shutter sync speed of 1/250 second. ... Shutter speed affects ambient continuous light, but does not affect flash (flash ... make continuous light be no factor at all, a totally black picture if with just the ... Which maynot be all bad if you want it, and it is your choice, determined by shutter speed.
Cameras can Kill ! - Photo.net Canon EOS Forum
Jan 25, 2016 | Cameras
Jazzy model 1103 - one speed and speed light flashes
hi,when the speed light flashes,is there a pause or is this a continous flash ?regarding missing a connection, that i very much doubt...
Regards
Rob
www.gewizrepairs.co.uk
Dec 12, 2013 | Pride Jazzy Select 6
1988 ford taurus wagon chimes everytime i go 45+ mph and the speed light flashes... what's wrong?
You probably have the speed reminder set to 45mph. It chimes & flashes to let you know you are speeding. It will tell you how to adjust it in your owners manual. If you don't like it set it high eg: 100mph. then it won't happen.
Jun 02, 2012 | 1988 Ford Taurus
I am using a Nikon D200. When using flash I can't raise the shutter speed any higher than 1/250. It seems to be locked there and I don't know how unlock it. Please help.
That's entirely correct. 1/250th is the fastest shutter speed you can use when using flash. Many other cameras can still only use 1/60th or 1/125. It's all to do with the two curtain nature of an SLR shutter: when you release the shutter, one curtain withdraws across the frame to expose and then a second one follows behind to shut off the light source. For exposures of 1/250 or slower on your camera, the second curtain does not start to travel across until the first one has fully opened, so you have a fully open exposure frame allowing the flash to reach every part of the sensor. At faster speeds, the second curtain sets off before the first one has finished and at the highest speeds it's so close behind the first that only a narrow **** is open to the incoming light as the shutter curtains pass across the sensor. If you fire the flash at these speeds the shadow of the first or second (or both) curtains will appear on the sensor and the picture will look like a narrow horizontal band, or if using fill in flash, it will look like a bright band across the picture.
It's immaterial though as the normal exposure rules don't apply with flash: the flash duration is typically anywhere from 1/4000th to 1/50000th and in that exposure time it outputs sufficient light onto the subject to enable a photo to be captured. As the flash is the dominant light source, the ambient light captured when the shutter is open for 1/250th is insignificant unless you're making a daylight exposure and using the flash for fill in purposes.
There are some specialist SLR and flash combos which will allow the full range of shutter speeds, but they do so by firing the flash multiple times very rapidly to ensure that there is flash light present effectively continuously as the narrow exposure **** passes across the sensor.
Compact cameras have shutters which work differently and which fully expose the sensor at all shutter speeds, so in that respect they can have a far more flexible flash exposure system. Unfortunately, they ruin it by having pathetically weak built-in flashes which are only good for very short distances.
Sep 03, 2010 | Nikon Cameras
I mounted the Canon 580EX II to my Canon 5D Mark II. When I using Manual Mode, I can't set the shutter speed more faster then 1/200 sec. Is this problem normal/limitation of it?
Yes. If you were able to set a faster shutter speed, then you would not expose the entire frame and would have the shadow of either the first or second shutter curtain (or both) partially masking the frame.
At higher speeds, the shutter is never fully exposed: before the first shutter curtain has finished travelling across the frame, the second one has stated it's journey. All SLR's have this issue and on some older models you could only use a maximum 1/60th of a second.
In practice though, in dark conditions the "slow" shutter speed does not affect exposure as the true exposure will be determined by how much light the flash puts out, and it puts this light out in as little as 50 microseconds (50 millionths of a second) for a modern electronic flash bulb.
Faster shutter speeds can be used successfully, but only with flashes which operate in high speed mode. What they do is to make the flash burst seem longer by rapidly firing the flash bulb many times. This trick can ensure that there is sufficient light to expose the frame at the highest shutter speeds. Shutters which operate at, say, 1/4000 may seem fast, but compared to the speed at which a single electronic flash burst operates, it's an eternity.
May 11, 2010 | Canon Speedlite 580EX II TTL Flash
The 100m light flashes but the 10m don,t flash even though connected but speed very slow
The speed you are connected to your network at is 100mbs.
the 10m light shouldn't flash unless that's the speed of your network.
the slow speed is probably due to the bandwidth usage to the internet.
if anything else connects the internet on the network it will share the bandwidth. also depends on the broadband speed you are subscribed to.
Mar 16, 2010 | D-Link DFE-690TXD Network Adapter
MY CHAIR WILL NOT CHANGE SPEEDS IT IS VERY SLOW AND WILL NOT INCREASE SPEED AT ALL. LIGHTS ON POWER LIGHT INDICATOR FLASHES CONTINUOULSLY
Your batteries are bad or not charged up is it only 1 red light flashing or is it all power lights flashing 1 red means not enough charge. all means internal problem with joy stick
Mar 05, 2010 | Pride Jazzy 1103 Ultra Standard Power...
My pics come out half black when I use the X-370 flash
motley45
this happens when the shutter speed is not correct. set the speed to 1/60 sec.
if the X-370 flash is new it may not be compatible with your camera. with the flash turned on it should set the shutter speed automatically to either 1/60sec or 1/125sec. looking in the finder the shutter speed should not change to various amounts of light. if the shutter speed changes with the flash turned on it is not dedicated to your camera.
May 03, 2009 | Minolta X-370S 35mm SLR Camera
How do i take photos indoors/ what settings do i use?
alexisalejan,
well first how far away from the stage will you be?
will you be using available light or a flash unit?
shutter speed and f-stop depend on the light source and film speed. (iso )
the faster the film the less you have to use flash, the lower the f-stop the less depth of field you have, the kind of flash is important, most flash units are good for only around 20 ft.
i would use a high speed film and not use flash. flash will kill any colored lights. try to keep the f-stop at least f/8 and the shutter speed no less than 1/60 sec. have fun.
Dec 13, 2008 | Nikon F60 35mm SLR Camera
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
281 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
