first of all you have to download the software updater from the nokia webite..and once your done,connect your cellphone to the computer with a USB cable..
update software:
With device software updates and application updates, you can get new
features and enhanced functions for your device. Updating the software
may also improve your device performance. You can update your device's
software using the Software Updater in your device or using the Software
Updater PC application. Learn how to update your device's software
using both methods.
It is recommended that you back up your personal data before updating your device software.
Warning: If you install a software update, you
cannot use the device, even to make emergency calls, until the
installation is completed and the device is restarted. Be sure to back
up data before accepting. installation of an update.
Downloading software updates may involve the transmission of large
amounts of data (network service). Make sure that the device battery has
enough power, or connect the charger before starting the update. After
you update your device software or applications, the instructions in the
user guide may no longer be up to date.
Update device software using your PC
You can use the Nokia Software Updater PC application to update
your device software. To update your device software, you need a
compatible PC, a high-speed internet connection, and a compatible USB
data cable to connect your device to the PC.
To get more information and to download the Nokia Software Updater application, go to
www.nokia.com.ph/softwareupdate.
Update software over the air
Your service provider may send device software updates over the
air directly to your device (network service). This option may not be
available, depending on your device.
Downloading software updates may involve the transmission of large amounts of data (network service).
Make sure that the device battery has enough power, or connect the charger before starting the update.
up data before accepting installation of an update.
Request a software update
- Select Menu > Ctrl. panel > SW update.
- The device scans for available updates.
- Select the desired update from the list, and follow the instructions on the screen.
- If the installation was cancelled after the download, to start the installation, select Install sw update.
The software update may take several minutes. If there are
problems with the installation, contact your service provider.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?what kind of error it shows?
When I opening a fb/Internet apps they showing, can't open this app at this moment
