Windows loads up in a short time bios starts to beep once but continues if computer is not turned off it will shut off its self
SOURCE: HP Compaq dc5000
Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
SOURCE: Acer aspire 7100 continually beeps while starting up
I had the same problem, I went to the keyboard and shut down the beep there is a check mark next to it and take the check mark off, the beep will stop
SOURCE: The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes
Failure Code
Fault Code Description
Solution
F0
Function key stuck
Replace touch pad or if touch pad is part of the clock, replace the clock
(ERC).
F1
Defective touch pad or clock (ERC)
Replace touch pad or clock (ERC). Touch pad is a more common problem.
Refer to F1 test at the top of this page for more information.
F2
Oven temperature too hot
Replace relay board, if present, or oven temperature sensor (RTD). Check
sensor harness.
F3
or
F4
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control.
Replace oven temperature sensor (RTD) if wiring is ok.
F5
Watchdog and hardware conflict
Replace clock (ERC).
F7
Function key shorted or stuck
(ERC).
F8
Analog / Digital problem
F9
Door latch
Check door latch components.
SOURCE: continuous short beeps on power up.Then shuts down
enter bios setup and check the temperature of your mobo and cpu if it's above normal and also check the cpu fan's speed if theres no problem with these three then try to remove all the expansion cards you have then reset the memory modules if the beeping continues try a different PSU and memory modules.
SOURCE: computer beeps 5 times and
5 beeps notes a memory error. Here are the possible solutions:
1.) Take the computer to a local repair shop and have the test/replace/reinstall the memory
2.) You can open the case and reseat the memory. You would want to follow proper procedures including unplugging the computer and following anti-static procedures by grounding yourself against the metal case.
3.) Reseating the memory means popping the latches loose and reconnecting (reseating) the RAM. This link has more details on the procedure.
4.) If reseating the memory does not fix the issue, you will want to replace the RAM.
