Monitors won't display while laptop is docked. Keyboard doesn't work either. Lenovo says to update firmware, but I need to dock the laptop while doing it, but when the monitors and keyboard won't work while docked, how can I update it?
SOURCE: thinkpad Dock station 2 won't charge docked laptop.
Most likely cause over on your part would be a bad connection from the dock to you. I am not an expert on laptop docks, but try to check that all the cables are nice and secure. Also, check that there is no stray objects in the connections. If all else fails, you may have a bad dock station.
SOURCE: dell computer won't work with docking station
reinstall the chipset and ricoh drivers from support.dell.com. also reinstall the notebook system software under utilities.
SOURCE: Docking Station problem
I had the exact same problem. When i undocked the laptop i had to reboot it when i put it back, in order to get the USB devices working. By updating the System Interface Driver, located here: http://www-307.ibm.com/pc/support/site.wss/MIGR-67228.html , the USB devices now power back up when you redock the laptop without having to reboot the machine.
SOURCE: Dell D630 Docking Station
First option if using Windows XP is to undock the system then delete the Docked hardware profile in Device Manager, Hardware Tab, Hardware Profiles. Once deleted, power off, dock the system, boot, Profile recreated.
SOURCE: how to connect dual monitors to docking station
one monitor you have onto laptop, second monitor connect to laptop connector for external monitor and in menu Start - Settings - Setting panels - "Icon - Viewing" and for this dialog window select folder "Settings" and configure secondary monitor
