Metra 2000 Chevy Tracker/Metro/Prism Logo
d
denver perry Posted on Aug 17, 2015
What to do to tracker not firing? - Metra 2000 Chevy Tracker/Metro/Prism
What is the distributor rotation on a 1992 Geo Tracker?
Rotation is different between 8 and 16 valve engines. See picture.
2answers
Where does the clutch fluid go in a 1992 tracker
open hood , look to drivers side fire wall look for a small black cap ,it will look like a very small brake fluid resivior
Where is the timing mark and what is the firing order for a 1995 Geo Tracker 1.6 5 speed manal transmission?
timing of what, cam or spark,..... why not say the JOB, so we can be on the same page...>???????
ILL GUESS DIZZY timing,
but we use the #4 firing to set the cam..so........??????
DIZZY answer.
8v or 16v , there are 2 engines, for sure.
and both are different. see why here.
1,3,4,2 is both but not the rotor
see here.
the DIZZY rotor
8v is CW
16v is CCW.
not knowing that is doom
and never read the GM book, it lies.
here is the index to all trackers.
http://www.fixkick.com/IGN_timing/index.html
When I try to start the tracker it does not fire up, it turns over but doesn't start
1.out of gas
2. fuel filter and /or pump (lack of fuel)
3. coil module (no spark)
4. camshaft sensor
5. crankshaft sensor
6. timing belt or chains
1helpful
2answers
Where is the fuse box ( interior ) 2003 4/dr Chevy Tracker
daughter drove tracker 50 miles to lake cabin and car stalled as she came into driveway, car turns over but no fireing could this be electronic fuel pump or what fuse or what?
2answers
Will the fuel pump prevent a 1999 chevy tracker from firing
Yes... the 'firing' is the fuel combusting in the chamber being ignited by the spark plugs.... No fuel? no fire.
1992 Geo Tracker wont start,no fire or fuel
You need a computer. I just went through the same thing
I have a 1990 chev tracker I pulled positive batt conection while
did you mess with the firing order cables? that could be the problem
1994 tracker
You may have an issue with the fuel pump crank circuit, check the ignition switch, I think that may be the problem
Top Metra Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
