Dehumidifiers Logo
g
gaye Posted on Aug 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The dehumidifier runs just fine with the exception of water filling up in the bucket. I want the water to drain continuously into a drain. How do i fix this?
J.D. Browning
Level 3:
  • Master 2,760 Answers
  • Posted on Sep 14, 2015
J.D. Browning
Master
Level 3:
Answers
2760
Questions
0
Helped
1013571
Points
6696
Well 1st not all machines are made to be a continuous drain type , if so your machine would have come with instructions on how to convert it over for this function , aside from that a little low tech approach to this (not too great looking though) is to drill /melt a hole into drain bucket just big enough to allow a hose bulk head fitting to be screwed into it (hardware store item) and use a simple garden hose for the drain connection
5 Related Answers
Anonymous
  • 883 Answers
  • Posted on Jun 08, 2007
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Mike Kolbay
  • 30 Answers
  • Posted on Aug 31, 2008
SOURCE: haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Anonymous
  • Posted on Nov 13, 2008
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Anonymous
  • 12 Answers
  • Posted on May 19, 2009
SOURCE: Danby continuous water flow will
Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
Anonymous
  • Posted on Jun 10, 2009
SOURCE: dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
How to make unit drain through hose, instead of filling bucket?
Assuming you have a hose connected to the bucket for drainage, it is necessary that the end of the hose be lower than the top level of the bucket or the bucket will fill before the hose drains. I see many people who have their units on the floor and run a hose up into a sink and wonder why the bucket fills. Gravity works.....if you cannot find a lower place to drain the water then you must raise the unit up on a table or stand of some sort to get the bucket higher than the drain.
Have model 043-6121-4 connected with a garden hose yet the bucket continues to fill.
Where are you running the hose to drain it? If the end of the hose is higher than the top of the bucket, then the bucket will fill and overflow. The drain hose must drain out into some place that is at least lower than the top of the bucket. That way the bucket won't overflow. Basic physics.
1helpful
The water won't run continuously out, instead the tank fill up. I have it set up to run continuous but the tank keeps filling up. I have the Westpointe dehumidifier.
Some dehumidifiers don't require that the bucket be in place, when a drain hose is attached to the unit. I'm not sure that's the case with yours, because I'm unfamiliar with the Westpointe brand. You should also check the drain connection that the hose is connected to. It may be clogged, which forces the water into the bucket instead of draining through the hose. If you have something flexible like a long plastic Zip Tie, that can easily be run into the hose connection and slowly pulled back out, while rotating it should loosen any clogs. Be prepared for water to follow. Do not use a wire coat hanger to do this and be sure the unit is OFF and unplugged from the wall, before attempting it.
Hope this helped you to troubleshoot and solve the problem. Please let me know.
1helpful
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Danby continuous water flow will not work on a dehumidifier it still fills the bucket
I hope that helps.
Top Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Dehumidifier Expert? Answer questions, earn points and help others
