Red light is still there, but it doesn't turn on when i try. I'm trying to turn it on by side screen button or remote doesn't work. Please help :
I was gaming that time, instead of turning off the display via Power Options on the PC, i turned off the screen it self. After an hour doesn't turn on at all. I did this for many times and it works usually though. But this time, its just i need help :D
Have you checked all the inputs to the television? It might be blinking because it doesn't see a signal. If all the inputs are secure try pressing the input select button on the remote. If that doesn't work it never hurts to try unplugging the power cord, waiting a minute, and plugging it back in.
1. Ensure that the Sensor Bar cord is plugged to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
2. Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
3. Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar.
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
I had the same problem the power button is pushed in. You did not mention if your unit came with a remote control if it did use that to turn your stero on and off. you will not be albe to use any of the buttons on the stereo if the controls are listed on the remote IE; Cd player, radio tape or tuner. try this please. hope this helps
Here are instructions from Nintendo on how to fix this issue. It's most likely related to the sensor bar. Good Luck!
If your screen appears
frozen at the Language select screen, we have found that to be related
to the Sensor Bar. Please try the following:
Ensure that the
Sensor Bar cord is plugged snugly to the back of the console, and is
Check
If
could be a problem with your Sensor Bar. Please read the following:
The
Sensor Bar has five infrared lights on each side of the bar that the
Wii Remote uses to determine its position. If these lights aren't
working, then the Wii Remote cursor will not display on the screen, and
you won't be able to navigate the setup screens.
To see these lights, you will need a digital camera or cell phone camera with an LCD display.
After making sure the Sensor Bar is plugged in and the power to the
console turned on, direct the camera at the Sensor Bar so that it is
displayed in the LCD
of the camera. If the five infrared lights can be seen on both sides of
the Sensor Bar, the Sensor Bar is working. While the position/angle of
the camera may need to be adjusted slightly, the lights are fairly easy
to see in the LCD display.
First press the SAT button at the top left hand side of the remote and release. Now try changing channels. If this did not work press the menu button twice on the receiver. It will usually be behind a pop open door on the right of the receiver. I f your receiver does not have these buttons you can access the system info screen by pressing the power button on the receiver while holding down the arrow left or right key.
Once you have come to the SYSTEM INFO SCREEN press and hold the SAT button on the top left side of the remote until all lights across the top light up. Then key in a two digit number e.g. 01-16 and press the #key. then press the record button and the remote address for the location you are trying to control should change to the number you keyed in. If this is the second location tv that was giving you issues exit out of all the screens on the receiver location tv and go to the other location and try the remote. If it is the tv where the receiver is located then you should now be able to use the remote to maneuver the yellow cursor across the screen. If you need furtherassistance please let me know. Thanks for using Fix Ya.
I dont have a clue what happened... The screen is blue and has a little red lock on the upper left hand side... remote only works to turn it on...no other buttons work. Help please!!!
