Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that
base unit by default is "paired" with only the 1 cordless handset that
came with it.
While you can plug both base stations into the landline wall plugs
(RJ-11), and when the line rings, both base unit phones will ring and
will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the
base unit they are Paired with. The cordless phone paired with the
CL84109 corded base unit will not be able to transfer or Intercom
between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally
came with the CL82409 base unit to work directly with the CL84109 corded
base unit, you can likely "Pair" them to work directly with the CL84109
corded base unit for a total of 5 cordless phones to be paired to the
CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for
instructions on how to Pair additional cordless phoned to this base
unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired
to it and will thus be useless from that point on. (unless you pair more
expansion cordless phones to it again)
