LG Flatron IPS224V-PN 21.5" LED LCD Monitor - 16:9 - 5 ms. 22IN IPS WS LED 1920X1080P IPS224V-PN VGA DVI HDMI 14MS 5M:1. AdjustabDisplay Ang- 1920 x 1080 - 16.7 Million Colors - 1,000:1 - DVI - HDMI - VGA - Black Logo
P
Paul Posted on Aug 14, 2015
DVI-D stuck in power saving mode
Works in HDMI and VGA modes. In DVI-D mode flashes up DVI-D Power saving Mode then goes black. Tried all usual cable and plug changes. On/Off the power etc. was OK unitl I attached a VGA cable from other computer for t/shooting other computer.
5 Related Answers
Anonymous
  • 215 Answers
  • Posted on Jun 03, 2006
SOURCE: digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
Anonymous
  • Posted on Oct 02, 2008
SOURCE: power saving mode knocks the computer out, have to restart
I have an LG Flatron 19" black w1952TQ that I bought on 2 Apr 2008; when it goes into sleep mode, will not recover. Did the online troubleshooting, reseting things, unplugging/replugging all cables, nothing works except restarting the computer, and that only works until it sleeps... Read more
Anonymous
  • 70 Answers
  • Posted on May 28, 2009
SOURCE: Digital Power Saving Mode
Go to your monitor power settings and turn off Hibernation and other monitor power schemes.
If this problem persist, request for more technical assistance from the manufacturers website
Anonymous
  • 208 Answers
  • Posted on Aug 13, 2009
SOURCE: LG w2361vg sometimes get stuck in DVI Power Saving Mode
Maybe you can update your video card driver. My wife notebook is connected at times to my DELL17" flat screen and ever so often it cuts off in the middle of something. I update the video driver and reset the monitor to factory settings and it's working like a dream.
I suggest, you use the menu buttons on the LCD and reset it ot factory settings, and possibly update your video card.
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on Sep 06, 2009
SOURCE: lg flatron w1952tq monitor goes immediatly into power saving mode
reinstall windows
Connection to PC
I have had the same problem. If you have a VGA cable shown at the bottom. You can hook that into your laptop into the TV. The slots look like a blue incovering. You can also look at the image below that one for more additional help....
images?q=tbn:and9gcsiv-gyi4jh5l6apvblrydzbiwzndoskvj3ytpifllclwa1qmks
images?q=tbn:and9gctjzjmvlnbu_yfg04yh87cl2mau36aexgpvkl7rwz0yczn0azmwaq
2answers
How do you get it out of the power save mode...?
The monitor usually goes to the power save mode if there is no Video signal input. Check your VGA/HDMI cable(the cable which is connecting the monitor and the system) try bloing air through the connectors and reconnect the cable properly. Hopefully this will resolve the issue.
My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
Hello, today i unluged my computer and monitor from the power socket in the wall, and cleaned out the dust from inside my computer, and when i plugged all back in, my computer will comeup with the "LG"...
That's probably a message from the monitor because it's not getting a signal from the computer. Look at the VGA cord where it plugs into the computer, or the monitor to see if you bent pins when reinserting the plug.
2helpful
3answers
LG32LZ55 TV GOING INTO DPM MODE
Hi Ben,
Did you ever resolve? I have the same issue.
Monitor goes to power save mode on startup
Sounds like a bad video card (if embeded "built in") then you need a new mother board
1helpful
4answers
Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
2answers
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
2answers
Analog power save mode
Are you connect via Analog (Blue VGA connection) or DVI (White Digital connection?
If you are connected via DVI, then you have to change the input select button to DVI
If you are Connected VGA, make sure the system doesn't have 2 VGA ports. If it does, connect to the other port.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
