SOURCE: HOW DO YOU SET THE CLOCK ON A SONY CDX-S2200 CAR STEREO
Press and hold select. Then press select repeatedly until clock adj appears. Then press display and the hour should flash. Press display to switch between hour and minute. Then use the volume up and down to set the hour and minute. Press select and the clock will start and the next setup display appears. Then press and hold select to finish. To display clock press the display button.
Hope this helps
SOURCE: Sony CDX-FW700
The manuals for this product can be found at http://manualshark.org/p/sony-4/sony-cdx-fw700-1131/
SOURCE: How to set the clock
Had a good look for you for the manual to get the clock setting procedure... couldn't find the model you listed, but did find a cdx2250 manual at the Sony site... but the link was dead!!!
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDX2250
I would try to email Sony direct, and I am sure they can send you a PDF of the user manual. Good luck:)
SOURCE: Set time clock on Sony Car CD Player CDX-GT100
Download User Manual of CDX-GT100 from Sony Support and got to page 4 for clock set procedure.
Thank you.
SOURCE: my Sony CDX-S2010 seems to
Go to the link below page 4 will tell you how to take off demo mode.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/158/158S2010.PDF
